93 Explorer A/C broken?
Old Jun 27, 2003 | 12:46 PM
3745's Avatar
3745
Unhappy 93 Explorer A/C broken?
A/C Problem!!!
I have a 93 Explorer Sport, 6cyl 4x4, and it seems the a/c just died on me today... The problem starts when I push the a/c button on, and turn the **** to the right (on). The a/c does nothing but blow warm air from outside (feels like)... It has worked fine for the last couple of years I've had it, but why all of a sudden?
Here are some symptoms of what's going on:
- In the morning, when it's cooler oustide, it seems to work ok when I'm driving to work. (20 min ride)
- While the a/c is on and blowing warm air (during the day), the rpm gauge fluxuates like it's trying to come on about once every 4-5 seconds', but I don't think it is really working... I remember when the a/c used to work properly, when the vehicle is just idling, the rpm's raised about 1-200 rpms- almost to 900 rpm's from idling at 750 or so.
- is this an electrical problem? Freon problem? Compressor problem?
- Could this be fixed without the help of an expensive a/c shop?
Old Jun 27, 2003 | 01:23 PM
fishin1976's Avatar
fishin1976
First, check that your compressor clutch is working. Open hood and watch that the front of the compressor is spinning. If not, Look for bad wire connection to the clutch, (unplug and plug back in), else the clutch is bad and needs replaced.
IF SPINNING:
Buy the A/C recharge kit w/ guage from your local parts store. Get the one that has the components seperated in the see through plastic packaging, the fittings should be all brass. Costs about $ 25. Follow the instructions to determine if you have any refrigerant left in your system. You should have 25-44 psi when the compressor is running, should increase to about 80- 100 psi fairly quickly when the compressor stops.
If the compressor runs only 4-5 seconds at a time, more than likely you have a leak and are out of refrigerant. If the pressure checks out, check the AC pressure switch.
Your compressor should run a couple minutes at a time to constantly with a proper charge. If the system pressure goes into the red zone on the guage (compressor running) get 2 cans of combo R134a and 2oz. ester oil or 2 cans r134a and 2 cans (4 oz.) ester oil for AC systems. If completey empty you have a leak.(check the condenser in front of your radiator, good place to start)
You may also replace one can of refrigerant with a can of combo refrigerant and stopleak, this may work for you.
Old Jun 27, 2003 | 01:28 PM
3745's Avatar
3745
Ok, it seems that the "compresser" isn't spinning like you had mentioned... I opened the hood on my lunch break today, and didn't see it spinning over a period of about 2-3 minutes... I'll go out there and see if I can find any bad wires.
Where do you recommend that I look?
Old Jun 27, 2003 | 01:36 PM
3745's Avatar
3745
Old Jun 28, 2003 | 05:22 PM
flashpt6's Avatar
flashpt6
So what if the compressor is spinning, you've checked the low pressure valve and its pressure is correct but the A\C still blows warm air???
Old Jul 27, 2003 | 09:48 AM
robjonrik's Avatar
robjonrik
Exclamation 93 Explorer A/C broken?
IF SPINNING:
Old Jul 27, 2003 | 10:24 PM
samhihn's Avatar
samhihn
The 93's generally came with an R-12 system..........If you're gonna change to 134a don't screw around with a Wally-world "kit". You will pay to do it "right" now or you will pay later. Just my 2 cents..........
Old Jul 28, 2003 | 08:46 AM
Toon's Avatar
Toon
Maybe a useful tip if you can't find any leak and still know your'e losing fluid (like I had):
The lower tube (aluminium) that goes from the evaporator core to the radiator is halfway supported by a steel bracket to the acumulator.
Since steel and aluminium don't get along, the tube will get corroded and leak.
Hard to see, we found out after adding some fluor which lights up under an ultraviolet lamp.
Good luck, Tony
Godfather15228
Jul 20, 2010 03:01 PM
Project_dog
Jun 14, 2010 09:27 PM
cavitation
Apr 28, 2010 10:16 AM
oshoguno
Aug 21, 2005 10:04 PM
3745
Jun 27, 2003 06:24 PM
