Heater Fan Issue
Old Jan 18, 2014 | 11:25 AM
TenStrings's Avatar
TenStrings
Heater Fan Issue
Hi All, My wife's 99 Ranger's heater fan is not working. It was working off and on until now. The fuse is fine. I went out this morning and tested the blower motor for power in --had voltage. Assuming the motor was bad, I pulled it. Before wasting $ and a trip to town, I bench tested it --it works. Now my question: what do I do next?
Old Jan 18, 2014 | 01:05 PM
sureshot-!'s Avatar
sureshot-!
Maybe start by looking closely at the connector plug & socket.
Old Jan 18, 2014 | 05:29 PM
Monteg0's Avatar
Monteg0
Sounds like a failing motor. Sometimes banging on them will make them work again for a short time. (pulling it out could be enough movement to do that) I had one that I would have to tap gently with a hammer to get it started. It was too cold outside to change it and too cold to not have one. Made it through the cold part of the winter doing that.
Old Jan 18, 2014 | 06:18 PM
Josh S's Avatar
Josh S
You could put the blower motor resistor on your suspect list too. It's right next to the blower motor in the engine bay. That ended up being mine's problem, although the fan would still work for me on the high setting. It's cheap/easy to change if that is the problem.
Old Jan 18, 2014 | 10:28 PM
Frozen_Joker's Avatar
Frozen_Joker
I was gonna say the resistor is likely the cause. I have had that resistor go out on me on 4 diff ford trucks.
Old Jan 19, 2014 | 12:12 AM
ford2go's Avatar
ford2go
Could still be the motor, but it could be the ground connection as well.
I think that they're usually grounded through the mounting screws ( not sure).
You might try checking that area.
Good Luck,
hj
Old Jan 19, 2014 | 07:35 AM
tomw's Avatar
tomw
You could take the motor apart and check the brushes. If gentle thumping with a 2X4 wakes it up, the brushes may be sticking, or worn so much they don't make good contact with the armature. With the price of the replacement being low, it is likely not worth fiddling with the old one, and if the resistor block checks out, I'd just replace the old with new.
Be careful about the polarity of the wiring. The blower squirrel cage will run backwards if you reverse the leads. The replacement I used had black & white wires to take the place of two distinctly other colored wires. I had to connect the new wires to the old factory connector.
tom
cedman
Jan 16, 2016 09:28 AM
Linne
Dec 16, 2012 07:25 AM
Dodge/Cummins
Aug 31, 2008 05:42 AM
rutang
Feb 2, 2007 12:28 PM
