Adjust speedo after tire upgrade??
I recently went up in size on my tires after installing a Leveling kit. Today for the first time since I had to take a long trip and was checking my speed against what the GPS was stating.. there is about a 8mph difference.
So if the truck says 65, the GPS was saying 73/74, and the faster I went the bigger the difference got.. so if the truck said 70, I was going closer to 79/80
I know that there needs to be some adjustments made so it read correctly again, just wondering if there is also some adjustments that can be made to get the RPM's down at crusing speeds also..
In the past when I would do around 70 or 75, the RPM's would be around 1500 to 1700, now im staying steady at 2000.
What am I looking at to get back to somewhat normal again?
Waiting on the dealership to call me back with a price to have them do it, but been looking around at programmers, if I decide to go with a programmer instead of a one time change from the dealer.. any brands better than others..
I found a hypertech brand "Max Energy Power Programmer" which will do the speedo and shift points and has more flexibility.. and alos just a speedo calibrator from them also..
Either ...
-click- the pic'
Goth 150
< This space intentionally -blank- >
A trip to your local friendly FoMoCo dealership service department to have your PCM flashed using their IDS (Integrated Diagnostic System) to adjust the RPM (Revolutions Per Mile) of your wheels.
Or ...- may be a slight charge for the service, depending upon your relationship with the dealer.
. - can only set the RPM to values that are for F-150 stock|option wheel sizes.
Purchase a hand-held tuner (e.g. SCT) to effect the same change yourself.
BTW ... This will also resolve your transmission's shift points.- would be able to set the RPM parameter to any value.
. - tuner will co$t $$$$$
. - tuner will leave a fingerprint for the change.
-click- the pic'
Goth 150
Go here:
Tire Size Calculator - Tire & Wheel Plus Sizing
Your GPS is giving you the proper speed. At this point, ignore how many rpms your turning as the taller tires have slowed down the number of revolutions per mile.
Either ...
A trip to your local friendly FoMoCo dealership service department to have your PCM flashed using their IDS (Integrated Diagnostic System) to adjust the RPM (Revolutions Per Mile) of your wheels.Or ...
Purchase a hand-held tuner (e.g. SCT) to effect the same change yourself.BTW ... This will also resolve your transmission's shift points.
-click- the pic'
Goth 150
-click- the pic'
Goth 150
So is it 2 things I need to have done? resting the revs and recalibrating the speedo? or is that one in the same?
Ill see when I can get a good pic, the only thing that sucks is that I forgot to take before pics.. which is something I do with all projects.. im restoring a 74 Camaro and I am always taking pics before, during, in between and after.. and for whatever reason I forgot on the truck..
but I can post some as soon as I can.
After the kit now I want just a tad bit more lift.. and looking to make more mods to the truck..
Like adding some super bright lights to the back under the bumper to help with reversing, adding the backup sensors and swapping out the headlight housings with the tinted ones.
before the change, yea I would notice that GPS and speedo would match. Now the speedo is about 8mph slower than the GPS.. so until I fix, just need to remember the difference.
IMHO if you're not towing often, and you can live with the slight decrease in performance with the more appealing aesthetics, you should be ok. My rpms are down not up as previously stated with the same size tires. I got an SCT from 5 Star and it corrected all the issues, I'd recommend Mike to anyone. My speedo is off some but I just make sure I'm not going faster than the others on the highway. Its closer at lower speeds on my truck. Theres a sticky for the brighter reverse lights, I did Rigid Industries SR-M diffused under my back bumper and tied them into the reverse wire for the trailer plug. Works great
cubangt - Is that all the possible options? the tires I put on are 295/70/18 which looks like suppose to be 589 Revs..
BTW ... There is speedometer gear.
-click- the pic'
Goth 150
Ok here is a pic after the lift before the tires(they hadn't arrived yet)
Here is a pic of the tires installed on the stock rims
Here is the truck lifted and new tires, but from different angle
Ill have to see if remember to park the truck in the same place and take the after pic and wash it also
