1990 E4OD transcooler
Old Jan 18, 2014 | 06:02 AM
Pellas's Avatar
Pellas
Hey guys.
I'm hopefully installing an auxiliary transcooler to my truck later tonight.
I'd like to know wich of the oil-lines to the radiator is the "hot" feed line and wich is the "cold" return though.
I'm trinking the upper one is the feed from the transmission and the lower one should be the return, but you never know?
Old Jan 18, 2014 | 01:21 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
front trans line is out from trans - into upper section of rad - out from lower section of rad - (install optional 180°F t-stat here) - into aux air cooler - out from aux air cooler - return to trans in the rear line.
if you used a correct size aux cooler,you'll have near perfect temps (175°F) almost all the time,year round with t-stat.
Old Jan 20, 2014 | 12:00 PM
Pellas's Avatar
Pellas
Yep that's pretty much what i have done now. Don't have niether a thermostat nor a temp guage. But i'm hopeing it won't boil over now at least.
Boiled over last summer so ended up splitting the transmission. Luckily it escaped relatively un-harmed but i then realized the stock cooling won't fly when driving slowly for longer durations. Ordered an auxiliary cooler right away but got the truck up and running before it arrived and only got around to inatalling it now, lol. :-)
Thanks for the info.
93'Bronco
May 13, 2013 07:04 PM
FABBB
13
Jun 18, 2006 10:45 AM
Jacob R
Mar 8, 2006 09:23 AM
rollnthunder_76
Jul 12, 2005 05:04 PM
wlihntr
Feb 17, 2004 06:06 PM
