Trans cooler for e4od questions
Old Apr 25, 2013 | 07:07 PM
93'Bronco's Avatar
93'Bronco
Within the next few days I want to install a trans cooler in y bronco when I ride on interstate or high speeds for like 15 miles or so it loses shift points and what not I've been told its an overheating issue the only cooling is the lines to the radiator which is the upgraded rad. Anyways my question is how do I go about this everything is stock is like to run bigger lines on the process and would I just basically make the trans cooler in-line with the radiator still assisting thanks for all the advice and help in advance.
Old May 13, 2013 | 04:04 PM
V10man's Avatar
V10man
Usually the added cooler goes after the radiator cooler. You sure you don't have one already?
Old May 13, 2013 | 07:04 PM
93'Bronco's Avatar
93'Bronco
It was taken out I believe cause a tranny line was already connected to radiator with short piwce of hose I already installed it in front of condenser so it gets the most cool air and it has worked fine unfortunately I now know I have a bad trans fluid temp sensor bad which means replace the whole shift solenoid
lud04X
Aug 15, 2016 09:21 AM
wastingas
Nov 25, 2012 04:24 PM
BIGFISH70
Jun 19, 2007 10:07 AM
cbremer
Apr 10, 2000 09:40 PM
