351c 1973
Old Jan 17, 2014 | 11:15 PM
mustang81's Avatar
mustang81
351c 1973
just found a 351c 1973 to be rebuilt. what can be done to the engine to get more hp/tq than stock 168hp? is it worth it or not ? just want to rebuilt and sell it back to have money to finish the 400 project.
Old Jan 17, 2014 | 11:46 PM
SDDL-UP's Avatar
SDDL-UP
Nope!
Save your money for the 400. In my opinion it's very tough to make money building an engine.
A - build a high HP "race" engine, complete with a dyno sheet for a small profit
B - build a common "generic" engine that many people may want for a very small profit (if you're lucky!)
Unless your name is Jon Kasse or you own the machine shop - walk away.
Old Jan 17, 2014 | 11:48 PM
85e150's Avatar
85e150
Compression and cam. Stock 168HP? That does not sound right. What vehicle was it out of?
Old Jan 18, 2014 | 07:07 AM
mustang81's Avatar
mustang81
Oups it is 163 hp.1973 cougar 2v.
Old Jan 18, 2014 | 01:16 PM
wyoming4x4's Avatar
wyoming4x4
good engine!
first question is what are you going to do with it and application! I personally like the cleveland and will build another. 400 ford great engine but aftermarket con rods not available. have to basically do a 434 from tim meyer for bullet proof btm end. cleveland lots of part for btm end bulletproof. not hard to make power with a cleveland and con rods pretty stout and some arp bolts. 7000rpm not hard to do with stock rods prepped up. good luck and chat later.
Old Jan 19, 2014 | 03:21 PM
BuzzLOL's Avatar
BuzzLOL
. Some KB flat top or mini-domed hypereutectic cast pistons plus a mild performance cam/lifters/springs (214/214 - 234/244 duration range @ .050" lift) should get the 351C right up into the 350 - 450 grossHP range easily (163 is netHP) of a muscle car engine... remove the air injection bosses blocking the exhaust ports if it has those... add a 4bbl. carb./intake and headers, or let your purchaser do that part... beware of general 'rebuilder' pistons, many have an undesirable lower compression height...
. Only need to convert your 400 into a 434 if looking for over 450 HP or so from it... otherwise, follow same formula as 351C above (using TMI/modified KB 351C pistons)...
Bud Mud
Apr 30, 2017 02:08 PM
daytomann
Oklahoma Chapter
Jul 17, 2014 08:36 AM
78fordbeast
Jan 26, 2013 05:16 PM
Econoline 150
Mar 9, 2010 08:26 PM
user 2833083
Jan 5, 2007 04:29 PM
