Radiator leaking - tough to replace?
Old Jan 17, 2014 | 08:15 AM
DoofusOfTheDay's Avatar
DoofusOfTheDay
Well, looks like my radiator is leaking. Not sure exactly from where but see it collecting on the bottom of the shroud. I need to go borrow a pressure tester to tell for sure and maybe see where it's leaking from. I replaced the radiator on my 1998 F150 and it was pretty easy. The only thing that worries me on this is the transmission cooler line. It looks pretty old and corroded. Worried about getting it off without busting it all up. I guess spray it with some PB a few times over a few days before I try and remove?
Any other words of advice?
Old Jan 17, 2014 | 11:08 AM
White Max's Avatar
White Max
Yes, use a good penetrating oil and line wrenches on your transmission lines. Replacing the radiator is a pretty simple job on these trucks.
Old Jan 17, 2014 | 11:41 AM
joey2fords's Avatar
joey2fords
it's been a long time since i replaced a rad, but with all the paper-thin aftermarket junk they are making these days, it might be worthwhile taking your old one to a rad shop for repair (save money by doing the re & re yourself, of course).
... or maybe i am out of touch ... is this even done anymore ? there are still rad shops out there, so i guess so.
install a new thermostat while you are at it ... saves you draining and re-filling later on.
Old Jan 17, 2014 | 11:56 AM
Fastback460's Avatar
Fastback460
There is still a radiator shop in my area, my bro had the rad on his T-Bird repaired.
They are pretty simple to replace I just did mine last summer. Just have to be careful when the lines are corroded.
Old Jan 17, 2014 | 12:02 PM
White Max's Avatar
White Max
If the factory radiator didn't have plastic endtanks, I'd suggest the same. In this case, a good aftermarket replacement will be of similar quality as the stocker was when new.
Old Jan 17, 2014 | 12:43 PM
Island'r's Avatar
Island'r
+1
Mine was leaking at the end tanks and coolant was collecting on the shourd, was relly hard to see where it was coming from. They are sealed by a large "O ring" Apparently you can try tightening up the crimp that holds the tank on... But I didn't wanna be stranded on the side of the road one day so I ditched it and got a new one.
They are surprisingly cheap. Mine was $190 out the door with tax.
I'd advise doing the Thermostat, upper and lower hoses, and heater hoses if you can swing it...
I didn't do the heater hoses on mine be cause they are not your standard hoses, and I was on a tight budget at the time... I really need to look into where to get them and how much they are...
Old Jan 17, 2014 | 12:47 PM
Island'r's Avatar
Island'r
Oh, and as for the trans lines... Soak em good... My lines came out, but the adapters that are between the lines and the rad fitting were seized in there... No big deal the new rad came with new adapters... But they wouldn't fit!!!
I ended up torching the old ones and tore the tranny cooler right out of the rad tank in the process of getting them out... No biggie though just a few curse words
Old Jan 17, 2014 | 12:48 PM
White Max's Avatar
White Max
Does this look like it?
More Information for MOTORCRAFT KH735
Old Jan 17, 2014 | 01:01 PM
Island'r's Avatar
Island'r
Something like that... Its the one that tees off for the Bypass.
Old Jan 17, 2014 | 06:42 PM
DoofusOfTheDay
This may be a dumb question, but if I borrow coolant system pressure tester from autozone do I need to plug like overflow tank hose or anything or just hook it up to top of radiator and pump it up?
Old Jan 17, 2014 | 07:15 PM
wag53's Avatar
wag53
The pressure tester seats on the shoulder below the overflow hole.
Old Jan 17, 2014 | 07:16 PM
White Max's Avatar
White Max
That depends on the pressure tester adapter. If it won't build any pressure, close off the line to the overflow tank.
EDIT: wag53 beat me to it.
Old Jan 18, 2014 | 12:50 PM
DoofusOfTheDay
+1
I got my pressure tester but engine too hot, and too cold outside and I got way too little sleep to start messing with this now. Tomorrow will mess with, but it does look like probably leaking from end tank on passenger side. I am with you, not gonna mess with trying to recrimp evenly on that end tank. I'd fix that and then the other one would go next month. Rockauto has them for $100 or so. You said $190, was that what you paid for new one and somebody to install or just $190 for the radiator and you installed.
Old Jan 18, 2014 | 11:58 PM
Island'r's Avatar
Island'r
$190 for the radiator... installed myself...
Old Jan 19, 2014 | 12:16 AM
Big_Al59's Avatar
Big_Al59
Just put one in mine last month. Radiator was 120 plus tax. Piece of cake to do, mine was manual tranny.
