coolant loss
Old Jan 16, 2014 | 08:43 PM
skinny29286's Avatar
skinny29286
if i did the ege delete and didnt change the oil cooler and later found out it was pluged what symtoms would it cause or damage
Old Jan 16, 2014 | 08:48 PM
9228.bobcat's Avatar
9228.bobcat
If you do the egr delete because you blew your egr cooler you have to change the oil cooler because thats the reason the egr cooler blew. If you dont change the oil cooler and it is plugged it will blow getting oil in your coolant, over heat and blow your engine if not caught immediately.
Old Jan 17, 2014 | 12:10 AM
04badford's Avatar
04badford
https://www.ford-trucks.com/forums/3...ch-folder.html
the 6.0L bible take a look and get familiar with locations . X2 on the Thermostat.
Old Jan 17, 2014 | 07:04 AM
Fal-308-Win's Avatar
Fal-308-Win
Originally Posted by skinny29286
no the egr valve didt look wet but it locked up after install ing a new one in less than a month ahd it did have some crust on the bottom of it but no wetness
Did you do this step right?? Run engine until it warms up to operating temperature (190*ECT. Or close) . Park truck overnight on a slight decline with nose down. In the morning before starting truck remove EGR valve, use a flash light to look down into the EGR port.. If Your EGR Cooler is leaking that is where you'll see Coolant.
troy676
Jul 6, 2015 01:25 PM
SUPERTEK94
Aug 21, 2014 11:23 PM
TexasBeachBum
May 12, 2013 09:07 PM
superdutyquest
Apr 6, 2010 07:30 PM
BillWoeb
Jan 27, 2006 05:28 PM
