coolant loss
Old Jan 16, 2014 | 05:27 PM
skinny29286's Avatar
skinny29286
coolant loss
I have been loosing coolant and believe it to be an egr cooler problem. But it onlly blows white smoke when its really cold thats it. And after it warms up notheing . Is that a definit egr cooler issue or could it be something else.
Old Jan 16, 2014 | 05:35 PM
9228.bobcat's Avatar
9228.bobcat
Could be either egr cooler or hg/cracked heads. Any coolant puking out of the degas bottle? What are you eot ect temps?
Old Jan 16, 2014 | 06:19 PM
skinny29286
ect temp whick i assume is coolant temp. is 168
no coolant is coming out of container
eot temp runs between 165 and 200 but is due for an oil change at 5000 miles on the change.
Old Jan 16, 2014 | 06:25 PM
jswartz84's Avatar
jswartz84
You could have some serious problems. You need a new thermostat. After replacing it, test temps again and report back.
Old Jan 16, 2014 | 06:41 PM
skinny29286
wouldnt that show on my scan guage 2 . what is the reading suppose to read on the coolant. Why do you believe it to be the thermostat
Old Jan 16, 2014 | 06:46 PM
jswartz84's Avatar
jswartz84
The thermostat should keep coolant at 190* give or take a couple degrees.
9228.bobcat
Coolant is supposed to run around 183- 195. Closer to 192 the better. Seems your thermostat is stuck open. Need to get that fixed first and get the temps up. Your oil temp needs to be within 15 degrees of coolant. But you cant measure the oil temp accurately until your coolant temp is up to par.
Old Jan 16, 2014 | 07:06 PM
skinny29286
ok i will hit that tomorrow . now wood that cause the engine to be loosing coolant and were on the engine is the thermostat located
Old Jan 16, 2014 | 07:13 PM
9228.bobcat
Its located on the end o the top radiator hose on the driver side. Thermostat wont cause you to lose coolant like your talking about. But in order to properly diagnose the problem you need the right temps. Have you pulled your egr valve and look and see if its wet??? If it is then yes your egr cooler is blown.
Old Jan 16, 2014 | 07:14 PM
jswartz84's Avatar
jswartz84
Follow the top radiator hose (drivers side) to the motor. Where the his connects to the motor is the thermostat housing.
A bad thermostat will not cause coolant loss. But the EGR cooler could be ruptured and leaking from a plugged oil cooler.
Old Jan 16, 2014 | 07:40 PM
skinny29286
no the egr valve didt look wet but it locked up after install ing a new one in less than a month ahd it did have some crust on the bottom of it but no wetness
Old Jan 16, 2014 | 07:41 PM
skinny29286
aslo if the oil cooler is pluged would a egr delete fix the problem
Old Jan 16, 2014 | 07:50 PM
9228.bobcat
The egr delete would cure the egr cooler from blowing. A new oil cooler will fix the oil cooler being blown. You need to determine if its egr cooler or head gaskets.
Old Jan 16, 2014 | 08:10 PM
skinny29286
what other semptoms would i see if it was a blown head gasket
Old Jan 16, 2014 | 08:31 PM
9228.bobcat
Anything over 16 lbs of pressure in the coolant system at wot. Normally it would puke out of the degas bottle, heat loss at idle in the cab, smoke out of the exhaust.
