duraspark
Old Jan 16, 2014 | 11:38 AM
monkey jason's Avatar
monkey jason
duraspark
I am putting new duraspark distributor in my 300 inline 6, goes in fine but last 1/8 inch. i'm not sure if it's bottoming or oring is real tight. where could i press without breaking something? any help would be appreciated.
Old Jan 16, 2014 | 02:43 PM
Franklin2's Avatar
Franklin2
It should go on in with little pressure. Your oil pump shaft is probably not lined up. See if you can grab the fan belt and turn the engine a little bit. It may drop in then.
MShepherd2
Jan 21, 2018 06:36 AM
redbayredneck
Jan 5, 2016 08:01 PM
Bootzz711
18
Jun 28, 2012 05:09 PM
slickeast
Jan 28, 2011 08:49 AM
xtrmbkr
May 18, 2003 09:46 PM
