Starter suge while starting
Old Jan 13, 2014 | 08:38 PM
guthrie&co's Avatar
guthrie&co
I would assume that my starting is going out on me. When I start the truck, the starter surges. It gets fast then slows and then back to fast. It also pulls the batteries down farther than usual. I do have new batteries, gpr and glow plugs. Is the starter going out?
Old Jan 13, 2014 | 09:29 PM
madpogue's Avatar
madpogue
Are you sure it's not just from a difference in compression among the cylinders? Is it the exact same cycle every time? I would try pulling the PCM fuse and cranking it for a while and try to get a sense of the time. If it's exactly once every two engine revolutions, I would suspect compression. Other thing to try, more work, would be to remove all the glow plugs and crank, see if it's still cyclic.
Old Jan 13, 2014 | 09:41 PM
guthrie&co's Avatar
guthrie&co
It does have a distinct cycle to it. I hope the issue isn't major. I went out on a limb buying such an old truck and I have always wanted an OBS. It seems all I do is spend money on it. At least I am not covering the same ground twice!
Clyde Percy
Feb 10, 2017 07:49 PM
Firefighter 1406
56
Jan 5, 2017 07:21 PM
Fatcatpaddy
Jul 7, 2011 03:45 AM
MustangMatt96GT
Mar 29, 2009 05:06 PM
ke5adb
Dec 22, 2008 06:54 PM
