4" OEM Rear Spring Blocks
Old Jan 16, 2014 | 08:26 AM
BobbyB's Avatar
BobbyB
I have read a lot of posts about adding 4" rear spring blocks for lifting. I have not been able to find a Ford part number. Would anyone happen to have them that will fit a 2004 F250 Crew Cab Short Bed?
Thanks!
Old Jan 16, 2014 | 09:24 AM
Unrealo4's Avatar
Unrealo4
The f350's had blocks that were 4.25 inches tall. The f250's had blocks that were 2.75 inches tall. I dont have part numbers but your looking for f350 blocks.
Btw other then the tag that is the only difference between a f350 and f250 well at least the srw versions.
Old Jan 16, 2014 | 10:01 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
If you have one of the following:
Crew Cab Short Bed (156" Wheelbase)
Super Cab Long Bed (158" Wheelbase)
Crew Cab Long Bed (172" Wheelbase)
Then use these part #s:
Blocks: F81Z5598 DA Qty: 2
Super Cab Short Bed (142" Wheelbase)
Regular Cab Long Bed (137" Wheelbase)
Left Tapered Block: F81Z5598FA Qty: 1
Right Tapered Block: F81Z5598GA Qty: 1
If F-250 is equipped with factory auxillary/overload springs use u-bolt part number 5C3Z-5705-AA. If F-250 does not have factory auxillary/overload springs use u-bolt part number N811667-S436. If you want replacement nuts, it's part number N620485S441 Qty: 8.
Old Jan 16, 2014 | 09:31 PM
BobbyB's Avatar
BobbyB
Awesome, Thanks!
powerstroker100
Jun 11, 2013 03:49 AM
SuperDutyScaler
May 28, 2012 05:58 AM
Rpayne
WTB - Parts & other
Jul 22, 2011 05:43 PM
allingeneral
Aug 23, 2010 01:40 PM
FX4 5.4
May 24, 2009 06:37 PM
