Won't start
Old Jan 16, 2014 | 08:10 AM
2000F250guy's Avatar
2000F250guy
Won't start
Hey guys, so this morning I go out and start my truck and it runs for about 10 sec and dies. Won't start again, doesn't even try. Noticed no blue smoke when trying. I opened and drained my water valve and turned key on to make sure was getting fuel. I'm thinking fuel filter??
Is there anything else I should look for?
Thanks guys!
Old Jan 16, 2014 | 12:05 PM
2000F250guy
Ok so i changed the fuel filter and got nothing. I scanned the computer and said PO1212, ICp voltage unexpected, I knew the sensor was going bad so i bought one a month ago so i changed it out and after a few cranks she pop and fired off. Then died about 10 sec later and back to nothing. Charging the batteries now.
Old Jan 16, 2014 | 01:17 PM
BillyBob69's Avatar
BillyBob69
Are you getting the WAIT TO START light? Check the 30 amp fuse in the panel under the dash.. is it blown?
What year is your truck?
Old Jan 16, 2014 | 01:56 PM
2000F250guy
I've checked the fuses, I do get the wts light. Someone at work mentioned the cam sensor.
Old Jan 16, 2014 | 03:18 PM
HKusp's Avatar
HKusp
Is the tach moving when you crank?
Old Jan 16, 2014 | 03:40 PM
2000F250guy
Am heading out right now to check that.
Old Jan 16, 2014 | 03:56 PM
2000F250guy
Tach moves to about 200-300< was hoping it was that..
Old Jan 16, 2014 | 04:09 PM
HKusp's Avatar
HKusp
Do you have access to a scan tool? Where are you if not, one of us with one may be able to help.
Old Jan 16, 2014 | 04:33 PM
2000F250guy
I do have a scan tool it reads P1212 (ICP voltage not at expected level), Earlier it had a different code about the exhaust valve, Cant remember the name of it. Friend deleted it. After some more reading it was suggested the IPR? Thats on the back of the HPOP if im correct. I will go and check to make sure that thin nut is on.
Thanks for all the suggestions so far.
Old Jan 16, 2014 | 05:26 PM
2000F250guy
The nut fell into the valley but the solenoid was tight.
Old Jan 16, 2014 | 05:28 PM
2000F250guy
im located in Bloomington MN
Old Jan 16, 2014 | 05:52 PM
78fordman's Avatar
78fordman
Need to know the ICP when it does start. You will need a scanner which will show live data. Does your oil pressure gauge come up?
Old Jan 16, 2014 | 06:15 PM
HKusp's Avatar
HKusp
Put that nut back on, I am sure you did. It didn't make a difference, so as Fordman, said, the next thing to look at is live data while cranking, ICP, RPM, vehicle voltage, would be good to start with.
Old Jan 17, 2014 | 06:59 AM
2000F250guy
oil pressure does go up
Old Jan 17, 2014 | 07:04 AM
2000F250guy
[QUOTE=HKusp;13962641]Put that nut back on, I am sure you did. It didn't make a difference, so as Fordman, said, the next thing to look at is live data while cranking, ICP, RPM, vehicle voltage, would be good to start with.[/QUOTE
The only live data i know how to get is from my gauges, Oil rises, Volts go down, Tach rises,WTS comes on, Check engine light isnt on.
I might just have it towed to ford since its only going to be 8 degreese today.
