Sponsored by: Real Truck
Need a hand with wiring.
Old Jan 14, 2014 | 12:13 PM
xmontex4's Avatar
xmontex4
Hey guys, I'm not a wiring guru so i thought i would post up here to see if what i came up with is OK or not. Let me know if anything is overkill lie the circuit breaker and relay ratings, that's just what the fuse block is rated for.
Abreviations:
BL - Bed Lightds
FL - Fog Lights
DL - Driving Lights
RL - Reverse Lights
any others you don't get let me know!
I have a couple of questions with wiring:
If i want to use a front and rear camera but only have 1 video input on the radio how would i go about doing that?
Also how do you wire in multiple carling switches? Do they each need an individual power source since most off them trigger relay's or do they need to be wired separate like i have above?
I'm trying to get all this figured to so i can just attack it when the time comes while also leaving space to add a few things later on like an air horn, compressor etc. I would like to have an idea of if i add the things previously listed how many would need relays and how the switches would need to get wired because I'm trying to keep this as clean as possible.
Old Jan 14, 2014 | 03:10 PM
02TB250's Avatar
02TB250
Abreviations:
BL - Bed Lightds
FL - Fog Lights
DL - Driving Lights
RL - Reverse Lights
I can't help with much.
But what are you trying to wire about the switches? If its the illumination then they can all be wired together.
But each switch really only needs to trigger the power in the relay for whichever device is powering.
As far as the video, you'll need a switcher look up treys thread about his "T.A.G.S" where he setup 4 cameras on 1 screen.
Sent from my Galaxy using IB AutoGroup
Old Jan 14, 2014 | 06:10 PM
xmontex4's Avatar
xmontex4
The illumination I had planned to daisy chain them off the dash illumination wire. I was trying to show the power source that will go to the relays and trigger my lights. I wasnt sure if I could tap them all off one circuit since its just trigger wires, if tgats the case I could reduce the amount of circuits I need and only use 1 fuse block.
I forgot about Treys thread thanks!
tbenks
Electrical Systems/Wiring
Jan 31, 2020 05:29 PM
styleside96
1997 - 2003 F150
Aug 17, 2012 01:25 PM
rebelyell618
Jul 23, 2009 08:07 PM
mclaughlin31
May 31, 2008 04:02 PM
Crazz
Nov 20, 2004 11:08 PM
