Hey there,
Anyone have any suggestions for an auxillary interior light i can mount in my 2014 SD? I know there was an older model light that clipped in a hole in the headliner, but i can't remember the year. I want to mount it in the center of headliner so i can more light in the mornings for center seat back(desk).
Thanks in advance.
not being a wise guy - you do know that there are two additional switches on the stock light, that need to be turned on at the light by flipping the switch. I did not realize that until a couple of weeks ago on my truck, they really light the interior up.
Until then I just used the light that comes on when I open and close the door or use the dash switch to turn the overhead light on. Then I discovered the switches built into the actual light - still might not be enough light for you - just wanted to share.
Lasallebaseball I'll see what I can come up with. I believe if you get on eBay and search your make and model and enter interior lighting you can find them. They use the OEM housing and are extremely bright and they look completely stock
Ok thanks Ill give it a try, Let me know if you find anything out... I have a 2003 f250 KR. Ive been around here for awhile and gotten a lot of great info, just decided it was time to start posting!
