Quick question
Old Jan 14, 2014 | 12:34 AM
Simplyrwc's Avatar
Simplyrwc
Quick question
With normal acceleration my ex up shifts at about 50-55 mph and makes a shuttering noise and has a slight vibration briefly during the up shift. Any ideas? Could a tranny fluid change help?
Old Jan 14, 2014 | 01:43 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
sounds like the TQ converter shudder some people talk about...i've never felt one do it myself. sorry i cant help
Old Jan 14, 2014 | 03:00 AM
Stewart_H's Avatar
Stewart_H
We kinda gotta know what engine you have in your Ex.
Stewart
Old Jan 14, 2014 | 03:02 AM
Simplyrwc's Avatar
Simplyrwc
Sorry. I have the V10
Old Jan 14, 2014 | 11:22 AM
EXv10's Avatar
EXv10
Change the oil if it needs it and cross your fingers. How many miles on it?
Old Jan 14, 2014 | 06:10 PM
Simplyrwc's Avatar
Simplyrwc
It has about 93000
Old Jan 14, 2014 | 08:22 PM
crazytwo's Avatar
crazytwo
Have you ever serviced the transmission?
Old Jan 14, 2014 | 08:24 PM
Simplyrwc's Avatar
Simplyrwc
No I have not done anything bit oil changes and tires. Have only had it about a year.
Old Jan 14, 2014 | 09:52 PM
EXv10's Avatar
EXv10
Maybe our pro, Mark, will chime in.
Old Jan 14, 2014 | 10:04 PM
JWC 3's Avatar
JWC 3
Sounds like convertor shudder . Feel like running over rumble strips ?
Old Jan 14, 2014 | 10:36 PM
crazytwo's Avatar
crazytwo
I'm not an expert so I'm not sure if a fluid and filter change will help at this point.
Old Jan 14, 2014 | 10:50 PM
Simplyrwc's Avatar
Simplyrwc
Not as rough as rumble strips more of a vibration like a back massager lol.
Old Jan 15, 2014 | 05:35 PM
JWC 3's Avatar
JWC 3
I use to see a lot of that in Lincolns and Crown Vic's . You can buy shudder fix for a temporary "fix " . I have had some luck using it for people that could not afford the repair .
Old Jan 16, 2014 | 11:47 AM
crazytwo's Avatar
crazytwo
My Excursion has a drain plug. I try to drain the pan every 2nd or 3rd oil change and change the filter every 25k miles give or take. When you drop the pan, the fluid is like new. I learned this after neglecting transmissions in the past and needing to replace a couple. I had a transmission fail in a Town Car recently at 315k mile. The only reason it lasted that long was the frequent fluid drain and fills. Before this I had transmissions fail at 175K.
Old Jan 16, 2014 | 02:10 PM
EXv10's Avatar
EXv10
That's way too much attention.........not needed.
gfl
Nov 13, 2012 03:50 PM
houtsdg
Mar 14, 2007 09:24 AM
66 mustang
Oct 12, 2006 07:54 AM
