STEALTH DELETE AND TUNE
Old Jan 13, 2014 | 05:39 PM
59203shop's Avatar
59203shop
Hey yall,
working on a 2004 f-450 super duty 6.0 L and i had some questions on doing a EGR stealth delete. I have done three 2005 trucks but this is the first 2004 i have done, which has the throttle plate EGR backpressure butterfly valve. On previous EGR stealth deletes on the 2005 trucks i have been able to use the SF3 pre programmed device to load a towing tune with egr off option with the EGR valve in place and plugged in. would this work the same for the 2004 truck, if i just unbolt the butterfly disc off the shaft and leave everything plugged in the tune will take and no CEL will come on? Let me know what you guys think.
Thanks
-winklershop-
Old Jan 13, 2014 | 06:36 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The SCT works the same way regardless of year.
You can modify the butterfly anyway you desire. Most bolt on a 2005+ elbow and delete it altogether.
Josh
Old Jan 14, 2014 | 07:24 AM
HeavyAssault's Avatar
HeavyAssault
I'd plug the EGR up-pipe that feeds from the passenger side as well. Then see if a CEL/code is displayed. If the customer wants a tune then the EGR valve function is limited with the SCT.
Prior to 2005 trucks have been known to not show a CEL or code when removing EGR parts alone. I removed the throttle plate on my 2004 with no issues.
Old Jan 14, 2014 | 09:28 AM
59203shop's Avatar
59203shop
yeah as far as i know the SCT preloaded SF3 comes with the 50 HP gain towing tune and the only options for the EGR is to turn it off. so i think i would be best just to remove the butterfly, leave the throttle plate and egr valve in and plugged in, perform the egr stealth delete (welding shut both ends of the stainless egr cooler) and then put the SCT SF3 towing tune on with the egr option off. the up pipe (that connects to back of egr cooler) doesnt have the scoop in it so i dont have anything to cut out there.
i also noticed that the HPOP is different on this year of engine, has anyone had any problems with them? i was going to do the SCT fitting update, but this hpop has a different connection all together, what experiences have you guys had? i just want to address it while i have access to it.
Also we will be rebuilding all of our injectors, i could definatly see the back to injectors were getting hotter than all the others, have any of you guy tried any of the fuel loop kits? to give even cooling and pressure to the injectors? some of them i saw come with a pressure regulator, which was around 8 bills....any out there more basic and less cost?
i was trying to read the serial number on the engine block to id the date of the engine but its so rusted i cant see any numbers. i ran a vin decode on the truck and this is what i get, i dont think any of that will help with the engine though? is there another place to look?
We are still learning, this is our first cab off job. look at the hole we found in the tranmission above the starter...haha...
Thanks for all your input!!!
<TABLE id=tblVehicleInfo border=0><TBODY><TR><TD class=labelCell>Vehicle Type:</TD><TD>Medium/Heavy Duty Trucks</TD></TR><TR><TD class=labelCell>Year:</TD><TD>2004</TD></TR><TR><TD class=labelCell>Make:</TD><TD>Ford Truck</TD></TR><TR><TD class=labelCell>Model:</TD><TD>F450 Super Duty 1 1/2 Ton Truck</TD></TR><TR><TD class=labelCell>Engine:</TD><TD>6.0 L 363 CID V8 Power-Stroke/VT365 Diesel</TD></TR><TR><TD style="HEIGHT: 15px"></TD></TR><TR><TD class=headerCell colSpan=2 align=center>VEHICLE INFORMATION</TD></TR><TR><TD style="HEIGHT: 5px"></TD></TR><TR><TD class=labelCell>VIN:</TD><TD>1FDXF46P74EC00788</TD></TR><TR><TD class=labelCell>Country:</TD><TD>UNITED STATES</TD></TR><TR><TD class=labelCell>Vehicle Type:</TD><TD>Pickup Truck</TD></TR><TR><TD class=labelCell>Year:</TD><TD>2004</TD></TR><TR><TD class=labelCell>Make:</TD><TD>Ford</TD></TR><TR><TD class=labelCell>Model:</TD><TD>F450</TD></TR><TR><TD class=labelCell>Engine Type:</TD><TD>V8, 6.0L (366 CID)</TD></TR><TR><TD class=labelCell>Assy. Plant</TD><TD>Jefferson County, KY</TD></TR><TR><TD class=labelCell>Production Seq. Number:</TD><TD>C00788</TD></TR><TR><TD class=labelCell>Body Type:</TD><TD>Regular Cab</TD></TR><TR><TD class=labelCell>Trim Level:</TD><TD>Base</TD></TR><TR><TD class=labelCell>Driveline Type:</TD><TD>4x2; Dual Rear Wheels</TD></TR><TR><TD class=labelCell>GVWR Class:</TD><TD>Class 4: 14,001-16,000 lb</TD></TR><TR><TD class=labelCell>Brake System:</TD><TD>Hydraulic</TD></TR><TR><TD class=labelCell>Restraint System:</TD><TD>Active Belts-Manual; Dual Air Bags-Front</TD></TR><TR><TD class=labelCell>Cab Type:</TD><TD>Chassis</TD></TR><TR><TD class=labelCell>Series:</TD><TD>F Series Super Duty</TD></TR><TR><TD class=labelCell>Vehicle Class:</TD><TD>Full-size Pickup</TD></TR><TR><TD class=labelCell>Fuel Type:</TD><TD>Diesel</TD></TR><TR><TD class=labelCell>Engine Manufacturer:</TD><TD>Navistar</TD></TR><TR><TD class=labelCell>Horsepower:</TD><TD>325HP</TD></TR><TR><TD class=labelCell>Manufacturer:</TD><TD>Ford Motor Company</TD></TR><TR><TD class=labelCell>Engine Code:</TD><TD>P</TD></TR></TBODY></TABLE>
Old Jan 14, 2014 | 10:50 AM
Bullitt390's Avatar
Bullitt390
Early 6.0 HPOP is garbage. Not if, but when it gives out.
If someone doesn't want a tune on the engine they can use the the Trans Only SCT tune with EGR off.
Josh
Old Jan 14, 2014 | 11:48 AM
59203shop's Avatar
59203shop
so the time is now to replace it, save some labor in long run, pay more for parts now. does the updated HPOP bolt right in a mesh correctly with the cam shaft?
whats your thoughts on the fuel loop?
the hole in the tranmission bell housing, must have been an aftermarket starter failure, i think we are going to patch it with an epoxy patch kit just to keep the dirt out.
thats a great idea on the tune, just do trans tune to get the egr off, before i would have to get a custom tune written.
BTW this truck only has 100,000 miles on it, but we were suffering from stiction and egr problems, so decided to tear into and we got to the point of no return so we are doing everything we can to get some longevity and reliablity out of the rest of the life engine.
Old Jan 14, 2014 | 07:35 PM
59203shop's Avatar
59203shop
any thoughts from any one?
also trucks prior to 2005 do not have hour meters, what have you guys been running for an hour meter?
Old Jan 15, 2014 | 12:16 PM
59203shop's Avatar
59203shop
..............bump
metmop
Jul 21, 2012 02:03 PM
DOGSINIT
Dec 1, 2010 07:17 PM
chrisbraziel
Sep 20, 2010 08:22 PM
AndeyHall
Dec 11, 2009 08:25 AM
mrsdbro
General Diesel Discussion
Mar 23, 2009 07:20 PM
