coolant leak...
Old Jan 13, 2014 | 12:57 PM
twobills76's Avatar
twobills76
coolant leak...
I have a 00 F250 7.3L and it has developed a coolant leak that is flowing off the oil filter...any ideas?
Old Jan 13, 2014 | 01:10 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Oil Cooler O-rings.
Old Jan 13, 2014 | 01:15 PM
twobills76's Avatar
twobills76
It is a small leak, haven't lost much coolant. My oil temp has been running normal so far. have noticed a small amount of steam also from top side of motor. Guess I will crawl under her this evening and check it out.
Old Jan 13, 2014 | 05:01 PM
F250_'s Avatar
F250_
Ditto on the oil cooler orings. When you do the repair, go ahead and replace the gaskets on the cooler heads where they mount to the engine block. It's a really messy job, and not worth doing a second time if you can get it all done in one effort. Most folks also couple this job with an oil change, and some also go ahead with the coolant flush (or conversion to ELC) as well. Like I said... better one mess than multiple messes.
Below is a link to the best source for the replacement orings and gaskets (if you can afford to wait the several days shipping time).
http://www.dieselorings.com/oil-cool...ate-94-03.html
T_balla_me
Feb 25, 2016 03:48 PM
tbill1313
Aug 26, 2014 08:08 PM
jtexfisher
May 5, 2011 02:03 PM
bad12jr
Jan 31, 2011 01:17 PM
michaelbrainardatwor
Mar 16, 2010 01:40 PM
