steering wheel adjustment
Old Jan 13, 2014 | 10:42 PM
madpogue's Avatar
madpogue
Turn the steering so the wheel is straight. Then turn it lock to lock. Count/observe how far it turns from center to the left and to the right. You could even take a pic of the wheel at the left lock and right lock positions and compare the angles, to see if one side goes further. If you get more in one direction (the same direction that the wheel is "off"), then you're golden with re-clocking the wheel on the column stub (again, you may have to grind a new key spline). If it turns the same amount from this "false" center position, then you'll have a tighter turning radius going in one direction than the other.
caprisecca
Aug 5, 2012 10:05 PM
cbzdel
Jun 20, 2012 10:24 PM
K80
Feb 26, 2012 11:15 PM
78Ranger400
Nov 20, 2010 09:22 PM
jimkari
Dec 26, 2007 11:42 AM
