Front cab mounts not level
Old Jan 13, 2014 | 06:10 PM
Lwlandy's Avatar
Lwlandy
It may not have been dropped but who ever welded in the box plates may have created too much heat that pulled it out of whack. Maybe, just maybe.
It was all perfect before it was shipped from the UK to the US.
is how it left my house in the UK..
is how it was delivered to my house in the US. Yes the Cab was mangled, the front fender was bent up as well. This was all while being shipped in a container for security and safety as it was not drivable.
its hard to see from this pic, but the complete front end was collapsed and the 3/8" thick steel plates on the suspension mounts had been bent right round from the force. If It wasn't dropped, I have no idea what could have done this.
Old Jan 13, 2014 | 07:17 PM
56panelford's Avatar
56panelford
Sorry, I didn't realize this was your project that you had shipped to your new location but was a vehicle you had bought that was misrepresented when purchased. It does however look good in the pictures. Obviously looks mishandled.
Old Jan 13, 2014 | 08:50 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Maybe the alignment/body shop can straighten it out again. When I was in Germany (in the 70s) they use to ship vehicles on Roll on Roll off ships (no containers) the vehicles would break loose and smash the front and rear ends up something terrible. I would think secured in a container they would have fared better. Although I have heard the container ship guys talk about losing containers overboard in storms.
Old Jan 13, 2014 | 11:53 PM
jimcar-9's Avatar
jimcar-9
The cab wings should actually drop 1/2" from the frame rails and out.
http://midfifty.com/item.php?INV_ID=4401
Make shure you look at the second picture available and also read the text under the picture when enlarged.
Old Jan 14, 2014 | 08:47 AM
Lwlandy's Avatar
Lwlandy
Thanks Jimmy,
That's just what I need. With this info and getting the frame checked for straightness I should hopefully work out what is up.
Cheers
Lee
Old Jan 14, 2014 | 09:02 AM
jimcar-9's Avatar
jimcar-9
Originally Posted by Lwlandy
Thanks Jimmy,
Cheers
Lee
Hey no problem I am just happy I can contribute to the community, I have had a lot of help myself by the guys that hang around at this forum.
Hope you will sort it out, and please gives us updates along the road
Old Feb 26, 2014 | 11:33 AM
Lwlandy's Avatar
Lwlandy
Just a quick update, I got the rolling chassis on a Jig and had it all measured. It looks like the chassis itself is actually within tolerances (well within 5mm/3/16", which for the age of the vehicle the chassis guy said was ok).
The only thing that needed to be done was to re align the Running board mounts. I will make up the 3/16" difference between the front cab mounts with a couple of washers, but might need to use an adjustable mount at the back to take up any difference.
Has anyone used the adjustable mounts from mid fifty/others. Can I get away with using just one and leave the fixed on the other side?
Thanks
Lee
whitey1371
Aug 23, 2016 03:20 PM
rk-rex
Dec 31, 2015 05:06 PM
Outlaw56
Jan 10, 2013 06:44 PM
benmoderow
Sep 5, 2009 09:59 PM
blueoval66
Dec 8, 2003 06:56 PM
