Hello,
My 95 4.0 has had a periodic idle issue for quite a while. It seems it may be getting worse. Here is when it may only happen:
Vehicle is fully warm. I shut it off for about 1 hr or so and when I restart it, it shakes and misses in idle. It will idle fine after I drive it around or if I rev the engine for a while when still parked.
This never triggers the "check engine light".
Fuel pressure regulator leaking gas into the cylinders when warm? Check a plug or two before you start it and see if they're wet. Personally, I'd guess your problem is fuel related somehow.
