4.9 rough idle
Old Sep 29, 2007 | 06:19 PM
beyermom's Avatar
beyermom
4.9 rough idle
I bought a early 1989 f150 4.9 6 cyl multiport fuel injection 5 spd it has had some previous owner work a lot of electric sensors and i have checked the fuel system it has a rough idle and stalls when cold then when it warms up to temp it does better but still has a rough idle and a racing problem.
Old Sep 29, 2007 | 07:31 PM
DrBones[LCD]'s Avatar
DrBones[LCD]
I also have a 'rough idle' problem...little different from yours. But..that said, I can tell you that from my research...starting problems on cold..and racing (i.e. surges in rpm's) are probably due to a bad EGR valve. That is, it most probably is stuck in open position.
Best is, check your computer codes firstl and then go from there though. If you don't know how to do that...buy yourself a manual for the truck...a very good investment if you're not a mechanic!
Old Sep 30, 2007 | 09:25 AM
JLDickmon's Avatar
JLDickmon
as far as the start & stall, are you using an ethanol-blend fuel?
Check the sticker on the pump the next time you fuel it.
Old Sep 30, 2007 | 10:52 AM
quicklook2's Avatar
quicklook2
plugs, or wires may be bad.
check iac = idle air control.
Old Sep 30, 2007 | 01:37 PM
JLDickmon's Avatar
JLDickmon
and it's probably so carboned up in the intake that it's sucking up fuel like charcoal lighter fluid..
