Steering column thread.
Old Jan 11, 2014 | 09:00 PM
PRIMERED79 SHORT BED's Avatar
I'm needing some help locating a thread that had pictures on the tear down of a steering column.
My turn signal cam isn't working, and while I'm at it, I would like to fix the side to side wobble my column currently has.
My column is the auto with tilt, and is need of some good ole repair.
Any help is much appreciated.
Old Jan 11, 2014 | 09:22 PM
lafermedavid's Avatar
lafermedavid
steering column rebuild advice ( 1 2)
NMFirstF2504X4 bronco graveyard has probably everything you need for that column
Old Jan 11, 2014 | 09:37 PM
Thanks lafermedavid.
My issue is the upper part of the column, its like the pivot pins are worn or something.
Old Jan 11, 2014 | 09:57 PM
lafermedavid
Turn signal Switch Id replace the whole thing ,not that big of a deal when its laying on your dining room table
Old Jan 12, 2014 | 05:15 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Here you go.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jan 12, 2014 | 10:08 AM
Thanks Rich.
Maybe you might know...
Some time ago a member posted up some pictures of his steering column rebuild, and if i remember right he had the same issues I'm having.
I tried to search last night but couldn't seem to find that thread.
Does that sound familiar to you?
Old Jan 12, 2014 | 10:21 AM
77&79F250's Avatar
77&79F250
Not off hand, did you use the "Advanced Search"?
Blue bar- New Posts Search (is a drop down) Quick Links
Maybe this guy...NMFirstF2504X4
Old Jan 12, 2014 | 07:09 PM
Cooter55
Mar 20, 2019 12:03 AM
LSCRX
Jul 26, 2018 09:49 AM
Qld G
Australia Chapter
Feb 1, 2015 10:40 PM
eman92082
Jan 3, 2008 07:55 PM
