About to set stuff on fire
Old Jan 11, 2014 | 05:32 PM
Mustangking1's Avatar
Mustangking1
Trying to get this friggin window seal on my sliding rear window.
Is there a different seal for solid vs. sliding windows?
This seal will not go on, no matter what i try, its a original 78 sliding rear window. Whats the best way to get it on?
I got it on last night but realized the friggin thing was on backwards now it wont go back on the correct way...
I've tried soapy water, hairdryer, bunch of tools, 3m blue painters tape.
Someone help before I set something on fire
Old Jan 11, 2014 | 05:45 PM
V10man's Avatar
V10man
You are using the roap trick right?
Old Jan 11, 2014 | 05:46 PM
Mustangking1
Yea im trying to
Old Jan 11, 2014 | 05:56 PM
HIO Silver's Avatar
HIO Silver
I have a somewhat different method but it takes a bit longer. I first glue/seal the weatherstrip to the glass and then let it dry overnight.
The next day I do the rope (nylon!) trick... and I find it easier to cheat the rubber over the body ending at the top. Meaning, the rope tails cross at the bottom when I start.
Old Jan 11, 2014 | 05:59 PM
5851a's Avatar
5851a
Is this the rubber trim with the aluminum trim? If it is, it's hard to deal with. More hands will help. Did a few and use the rope install but had to break out the nylon trim sticks for those. Prefer the one piece solid moldings, could zip those in in a minute by myself. Worked in a glass shop for 15 years.
Old Jan 11, 2014 | 06:03 PM
brian1080's Avatar
brian1080
there are different seals. Is your sliding window glass on the outside edges or does it have aluminum frame?
Old Jan 11, 2014 | 06:16 PM
Mustangking1
No trim and has aluminum frame.
Old Jan 11, 2014 | 06:37 PM
5851a's Avatar
5851a
Same size window from 1973 to 1996, where is it giving you trouble in the corners?
Old Jan 11, 2014 | 06:52 PM
Mustangking1
Getting it to go on inbetween the corners, corners actually are mostly on there, its like the cut isnt wide enough to go on
Old Jan 11, 2014 | 06:58 PM
5851a's Avatar
5851a
Make sure it's seated across the bottom all the way, it's wider there than the top. Keep trying to push it down.
Old Jan 11, 2014 | 07:25 PM
5851a's Avatar
5851a
Wife says time for supper, happy wife happy life. Let us know how it goes. I'm in NE Iowa if wasn't to far I'd come and help.
Old Jan 11, 2014 | 07:42 PM
JWC 3's Avatar
JWC 3
I use thin rope and soap , wd , to install . Did Many VW's , all models , GM trucks that way . Glass stick tool helps ( thin tapered nylon scraper looking tool ) Old rubber can be hard to work with though . If too old to be pliable , get new rubbers . Not that expensive .
Old Jan 11, 2014 | 08:15 PM
paredneck33's Avatar
paredneck33
Hang in there bud. You'll get it. Take a step back grab a cold one maybe a smoke if you do that and then give it another try.
Old Jan 11, 2014 | 08:23 PM
JWC 3's Avatar
JWC 3
Originally Posted by paredneck33
Hang in there bud. You'll get it. Take a smoke if you do that and then give it another try.
Wow... Much better !
Old Jan 11, 2014 | 08:49 PM
lafermedavid's Avatar
lafermedavid
Take a step back grab a cold one you'll get it
