About to set stuff on fire
Old Jan 11, 2014 | 10:14 PM
Mustangking1's Avatar
Mustangking1
Its brand new precision weatherstrip. It just doesnt want to go on for the life of me, does soneone have a picture of what the correct weatherstrip is with correct cuts in it.
Im thinking this is the wrong weatherstrip....
Old Jan 11, 2014 | 10:41 PM
tasboj's Avatar
tasboj
Maybe it was right the way you had it in first,If it was the wrong one you would of got it in to begin with. keep trying
Old Jan 11, 2014 | 10:47 PM
Mustangking1
Just figured out its a aftermarket prestige sliding window.
Might just put a solid rear window in
Old Jan 11, 2014 | 11:08 PM
brian1080's Avatar
brian1080
I have about 4 different rear windows, the one I have with an aluminum frame won't fit the rubber for a regular window. The alum frame is about 1/2" thick where the glass is 1/4" ish. All the other sliders I have that have no frame will fit the same gasket as a solid window.
As for anyone that says there is only one gasket, that is not correct and I can prove it. Maybe that window is aftermarket, but it does indeed have it's own gasket (referring to mine, yours may be the same).
All of my windows were pulled by me from 78/79 trucks.
Old Jan 11, 2014 | 11:57 PM
paredneck33's Avatar
paredneck33
Can you post some pics of what your working with? That may help us.
Old Jan 12, 2014 | 02:30 AM
SuperDuty93's Avatar
SuperDuty93
I got mine in with the rope trick but now when it rains the little slider channel fills up with water and then starts to spill over on the rear side into the cab!!! I had help from the local glass shop to and they are coming back to help me take it back out and see why it isn't draining and we are going to put a waterproof elastic type sealer under the rubber as well so no water can seep in...
But back to you. Was your truck ever in an accident? Maybe the window is warped but it took us (3 of us) a hour to get mine in the fit was so tight.
Old Jan 12, 2014 | 05:27 AM
5851a's Avatar
5851a
Brian 1080 is right about that thick slider gasket, the groove for the glass is like half inch wide. IIRC those were the factory sliders. Don't think you would ever be able to get the factory slider over the flat glass rubber. The aftermarket types we sold and installed all had small fin around outside that fit in the flat glass channel. I don't care for sliders, most will leak at pressure wash and pita to clean. Tinted flat glass for all of mine.
Old Jan 12, 2014 | 11:09 AM
Mustangking1
Where did you guys get your rear window seal? The one I have is from blue oval truck parts.
Where can I get a actual slider window gasket?
Old Jan 12, 2014 | 07:21 PM
5851a's Avatar
5851a
I have never bought the factory slider gasket but they were in the old crash books as a Ford Part. Last flat glass gasket I bought was from Ford but that was 15 years ago and wasn't bad but the prices have went through the roof on Ford parts the last few years. They must have taken a tip from import dealers parts dept. I would just go to salvage yard and pop one out of the newest unweathered truck I could find. Up to 96 on F150.
Old Jan 12, 2014 | 07:29 PM
Mustangking1
I have a ford truck parts place close to me, I am going to take my window in there and the new and old rubber.
Hopefully I can figure out whats up.
Old Jan 13, 2014 | 07:39 PM
Mustangking1
Took it to a parts place near me and they said i need a actual sliding window seal, that i have the wrong seal,
They suggested lmc,
What do you guys suggest and if you could include part numbers?
Old Jan 13, 2014 | 07:46 PM
paredneck33
I would suggest either a obsolete parts supplier, good reputable local glass shop, or steele rubber for a new seal. Why can't you use the old one though?
Old Jan 13, 2014 | 07:58 PM
  #28
Mustangking1
Rubber Was cracked. Would let water in.
Old Jan 13, 2014 | 08:04 PM
  #29
paredneck33
Oh ok. Sorry your having so much trouble with that. But I would think a good local glass shop might be able to help you.
Old Jan 24, 2014 | 04:53 PM
  #30
Mustangking1
I went to go buy a solid rear glass from a salvage yard and they said the window from a 95 that they have wont fit my 78?
blk450er
Sep 23, 2016 11:44 PM
dthut
Feb 23, 2016 11:45 AM
Ford247
18
Oct 1, 2014 11:19 PM
MGT351
Apr 5, 2004 05:54 AM
dust3
Aftermarket Products
Nov 19, 2001 09:54 AM
