What engine do I got?
Old Jan 11, 2014 | 02:37 PM
mitchdowd24's Avatar
mitchdowd24
This is going to sound really silly to a lot of the more veteran mechanics on here but what engine do I have. I just bought a 1977 F-100 2wd flareside and I'm restoring it. The guy I bought it from said it was a 302. I needed to repair the fuel pump because it had been sitting with old gas in it for a couple of years. The 302 fuel pump did not fit but a fuel pump for a 351 did. Alright so i now know it is a 351 but I know there are a lot of different types of 351's. The first 5 of the vin is F10HR. I heard the R means something but I don't have a clue. Any help?
Old Jan 11, 2014 | 02:49 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Engine Identification
The 351W and 351C did not come stock in 73-9 trucks. Some of them have been "transplanted" tho.
Engine Identification:
351C/M/400 335 series: 8 bolts in rectangular valve covers. Timing chain housing is part of block. Thermostat housing on block. Exhaust bolt holes diagonal.
351M/400 335 series: intake is 12.7" wide the 351C is narrow. The 351M and 400 are identical externally, only internal parts examination can tell them apart.
351W/302/5.0L 6 bolts on trapezoidal valve covers. Thermostat housing on intake. Exhaust bolt holes horizontal.
429/460 385 series: 7 bolts in rectangular valve cover
352/360/390/427/428 FE series: Intake goes under valve covers.
Ever get into here much? You should spend some time in here it has a ton of knowledge;
https://www.ford-trucks.com/forums/1...mpilation.html
https://www.ford-trucks.com/forums/1...ease-read.html
Old Jan 11, 2014 | 03:04 PM
77&79F250's Avatar
77&79F250
Well if what I got located it right.....
F10 is F100 2 Wheel Drive
H is V8 - 351cid - 2BBL carb - 1973-80
R is assembly plant code R is San Jose, CA
But might be wrong as hell and someone will for sure let me know.
Old Jan 11, 2014 | 03:45 PM
Jeremy Kamutzki's Avatar
Jeremy Kamutzki
Looks right by this site Decoding '73-'79 Ford Truck VIN Tags - FORDification.net
Old Jan 11, 2014 | 03:51 PM
mitchdowd24
awesome
so it looks like a 351. It has 8 bolts on the valve cover so by your handy chart there it is a 351C or 351M. I haven't really paid to much attention to the air intake but I'm going to go take a look. Thanks again for the quick reply.
Old Jan 11, 2014 | 04:02 PM
77&79F250's Avatar
77&79F250
Make sure and take the time to get deep into those "read first" threads. They are locked to the top of this forum for a reason. Lots and lots of info.
King_of_Norway
Jan 14, 2006 08:23 PM
mmacsek
Nov 30, 2005 03:56 PM
greenmachine76
Aug 14, 2005 05:54 PM
Blueoval_racing
Jul 17, 2004 08:30 AM
Hotrodder
Apr 3, 2004 07:57 PM
