Transmission inspection question
Old Jan 11, 2014 | 12:23 PM
desertwest's Avatar
desertwest
Trying to plan what to do about my transmission as I rebuild this truck. I know it looks like I drug it up from the bottom of the ocean, but how can I know what shape it's really in? It came with the truck which hasn't run in 15 years (and I've personally never seen it run). I'll try to figure out how to open it up in a couple of weeks but I won't know what I'm looking at really. Would much be wrong with a manual? What should I look for besides metal shavings, broken gears and dead bodies?(Lol)
Any test and inspection tips much appreciated.
Best I can tell is it's the original (64 F-100 2wd 4-speed) T-98... VIN says T-98. Number Dummy and you guys prob know just by looking! Will take some scraping to find the number. (The truck came with a 6 but was replaced w a 292 long before I got it). Looks like rebuilts are pretty pricey, kits are too and I'm probably not the guy to rebuild one so hoping this one is useable as is (wouldn't that be nice!)
Thanks!
Old Jan 11, 2014 | 02:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No VIN of any year FoMoCo vehicle contains the TRANS code.
1957/79 trucks: TRANS code stamped on 2nd line of Rating/Warranty Plate.
F ~ 1957/64: Warner T-98 / 1965 and later: Warner T-18.
Trans could have worn syncro brass blocker rings, bearings; leaking seals/gaskets; chipped teeth on gears and gawd only knows what else.
You'll have to tear it down and inspect.
Old Jan 11, 2014 | 06:55 PM
desertwest's Avatar
desertwest
My bad, Bill... I have always called the warranty plate the "VIN plate". Guess I'll just peek in there and see if everything is unbroken and tight. Cross your fingers!
Old Jan 11, 2014 | 07:09 PM
85e150's Avatar
85e150
Contrary to what my dad was told 30 years ago for his F600, it appears parts are available for the T98:
Parts for the Borg Warner T98 Transmission
Old Jan 12, 2014 | 08:33 AM
schoo's Avatar
schoo
I used Novak and border parts, border parts was a little hard to get parts from but a little less $$$$
Old Jan 12, 2014 | 06:28 PM
desertwest's Avatar
desertwest
"I used Novak and border parts, border parts was a little hard to get parts from but a little less $$$"
Thanks!... That's not as bad as I expected. Wondering if I can do it myself!
Old Jan 13, 2014 | 08:08 AM
schoo's Avatar
schoo
You can do it, border sent me two front bearings I didn't catch it until I drove for awhile popping out of gear took it apart again and looked at two much space on the shaft and started looking at the bearings and found that the rear bearing is a little wider than the front my fault ck your parts don't trust any parts guy except ND
Texasvintage
32
Dec 23, 2019 11:07 AM
K2thO
May 15, 2019 12:26 PM
'94Nichols
19
May 1, 2019 08:52 AM
1965GTFB
Jan 27, 2018 12:41 PM
hot-rod
27
Jun 16, 2010 08:23 PM
