Heater Problem?
Old Jan 10, 2014 | 11:35 AM
defiantoutlaw's Avatar
defiantoutlaw
Heater Problem?
My heat is not blowing at all. Seems like the blower motor is not working.
Before I start troubleshooting, is there a common issue with these, such as a relay, switch or motor that goes regularly? I'd like to have a head start on my troubleshooting.
Thanks!
1978 F-250 Supercab 4x4
Old Jan 10, 2014 | 12:12 PM
fmc400's Avatar
fmc400
MSEE
Does it work on any speed, or no speed at all? Does this truck have AC?
Before doing anything, verify continuity of the fuse with a multimeter.
Old Jan 10, 2014 | 12:49 PM
defiantoutlaw
yes sir, it has A/C that is disconnected. The fan does not blow at any speed. Breaking out the multi meter now, thanks!
Old Jan 12, 2014 | 10:29 AM
defiantoutlaw
It now blows, but only on high setting......and it will only blow for 5 minutes at a time, then shuts off.
Maybe the switch? possibly a relay?
thanks.
Old Jan 12, 2014 | 01:29 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
You are in great hands with fmc400 follow his guidance and you will have heat shortly, I bet.
Old Jan 12, 2014 | 02:34 PM
fmc400's Avatar
fmc400
MSEE
What changed in between it not working at all and now working for short periods? I assume the fuse was good? What about when it fails?
Old Jan 12, 2014 | 02:44 PM
mikeo0o0o0's Avatar
mikeo0o0o0
If it works on high speed only, check the blower resistor. It's easy to check visually. Take it out and look for any broken resistor coils.
Old Jan 12, 2014 | 02:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
In the last picture I posted, that resistor is bad. If you look closely at the coils that are at about the 3:00 O'clock position, you can see a break in the coil.
Old Jan 12, 2014 | 03:30 PM
fmc400's Avatar
fmc400
MSEE
Definitely check out the resistor, as that will explain only functioning at full speed. The shutting off at full speed after 5 minutes is a separate issue, as the resistor is bypassed in this mode.
'99-v10-F350
Nov 13, 2013 11:02 PM
Mrbiff
Oct 27, 2011 10:30 AM
mike duprey
Jun 17, 2011 05:07 PM
Ibuildembig
Dec 7, 2009 11:04 PM
pbuffing
Electrical Systems/Wiring
Nov 3, 2004 11:59 PM
