decode the diff tag
After 92, they lengthened it, not a lot, but enough.
The 10.25 and 10.5 share the same diameter pinion gear. The ring gear size is the difference by .25 inch.
The 10.25 uses a thicker pinion bearing at the head of the pinion as seen here
They use the same carrier, and carrier bearings.
I'm sure it could be a 10.25 under that excursion. Ford did weird things on some model years. Being its a 2000, it could have got a axle off the super duty pile for the 99s. It doesn't really matter. Mine has 10.25 gears in it, a 10.25 LS, and a 10.5 pinion yoke. The difference is really just .25 of a inch on the ring gear.
Also, yes, you have a limited slip in your rear axle.
http://image.fourwheeler.com/f/96191...ine_length.jpg
Found under: '85-'92 F-250 and F-350
Type: Full-float, semi-float (depending on gross vehicle weight)
Weight (lb., approx.): 310 (single wheel), 330 (dual wheel), 258 (semi-float)
Ring gear diameter (in.): 10.38
Pinion shaft length (in.): 10 1/8
Pinion shaft spline count: 31
Axleshaft spline count: 35
Axleshaft diameter (in.): 1.5 (at the splines)
Hypoid offset (in.): 1.50
Gear ratio range: 3.08-7.17
Found under: '93-'98 F-250 and F-350
Pinion shaft length (in.): 10.50
Found under: '99-'05 F-250 and F-350
Type: Full-float
Weight (lb., approx): 333 (single wheel), 348 (dual wheel)
Ring gear diameter (in.): 10.50
The 93-99 10.25 and the 10.5 can use the same pinion yoke.
But only briefly
What's the thing just left of the ring gear that looks like a tone ring or something?
Nerdily fascinating thread, this. Reminds me I need to crawl under my rig n double check the tag.
LOL indeed it is
So from what I've learned here looks like I have on my 2000 v10 4x4 a:
Sterling
138 F model
3.73 with no limited slip
10.5"
Oct 18 1999
I would bet by that model from the way you guys talk that my axle came off the Superduty pile which led me to be curious to know what my build date was, when I opened thedoor to check that all that was present was a white square with the word "void" all over it like it had been peeled off! Any way to decipher build date any other way? Figuring mine is an early 2000.
Sterling
138 F model
10.5"
Oct 18 1999
A Jan
B Feb
C Mar
D Apr
E May
F June
G July
H Aug
I - skipped
J Sept
K Oct
L Nov
M Dec
