Codes 452 and 634 and no reverse lights
Old Jan 9, 2014 | 08:40 PM
spyder0382's Avatar
spyder0382
I've repaired wiring issues replaced grounds and sensors. Replaced leaking capacitors inside pcm now down to my last codes. Before repairing the pcm I've heard of bad grounds from the pcm I came across an old tsb saying to add another ground to pin 46 for the exact issue. Trans slips bangs into gear feels like it starts in a higher gear I've cleaned the rabs sensor or vss sensor, cleaned and lubricated vss , mlps, main bulkhead, and pcm connectors. All fuses are good. I think I have a defective mlp sensor
Old Jan 9, 2014 | 08:48 PM
spyder0382's Avatar
spyder0382
yes bulbs are good
Old Jan 10, 2014 | 05:59 AM
Dennis-Pa's Avatar
Dennis-Pa
check the fuse box under the hood for the reverse lights
Old Jan 10, 2014 | 10:20 AM
spyder0382's Avatar
spyder0382
I did aleeady check that
fallconroe
Mar 1, 2025 09:52 AM
beefey
Nov 25, 2017 05:06 AM
exbxtoy
Jan 30, 2015 09:53 AM
7700f150
1997 - 2003 F150
Dec 7, 2006 02:47 PM
nixon_ca
1997 - 2003 F150
Mar 30, 2005 01:09 PM
