Occasional miss
Old Jan 9, 2014 | 08:37 PM
Killgore's Avatar
Killgore
Occasional miss
Hey guys i have a puzzler on my 390. She occasionally misses at idle in park. In gear it isn't noticible. I did the math and at idle the engine is rotating around 11 times a second. It only hits maybe 20-50 seconds apart from each other. So it fires fine for a while, a random misfire, then its okay again
Old Jan 11, 2014 | 09:31 AM
lee's Avatar
lee
What are the conditions of the plugs and wires? New, old?
Does it do this when only cold start up or only hot start or?
If when hot only I would consider that the coil is breaking down.
Good Luck,
Lee
Old Jan 11, 2014 | 09:36 AM
Killgore's Avatar
Killgore
Plugs and wires are brand new. Accel 8mm, accel super coil, and autolite double plat spark plugs. It becomes more frequent in the winter and when its cold. When warmed up it stops.
Old Jan 11, 2014 | 10:23 AM
lee's Avatar
lee
Hum.... grasp'un at straws here.
Is the choke open all of the way?
Does this only happen at idle? How does it operate while driving?
Wonder if the Carb is Loading up?
Old Jan 11, 2014 | 10:26 AM
Killgore's Avatar
Killgore
Its an electric choke, I do believe it is open fully. It only happens to about 650-1500 rpm in park. Once you start driving or it gets warmed up it stops
Old Jan 11, 2014 | 10:35 AM
lee's Avatar
lee
Grasping at more straws here.
I see you are in Kansas. How cold is it when you have the trouble? I ask because I wonder if the Carb is icing up.
Are you running the stock air cleaner with the heat riser tube or ?
Old Jan 11, 2014 | 11:05 AM
Killgore's Avatar
Killgore
It is the same in the summer and winter until she gets warmer or in drive. I have an open element air cleaner on
Old Jan 12, 2014 | 10:59 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Is it points? Because everything else seems to have been checked or is new...
Check the top bushing in the distributor. If it's loose, it can cause all sorts of whacky things. Even if it's an electronic distributor, the gap between the pickup and the wheel, if it changes at all, can cause weird things.
Also, since you say it stops when it warms up fully, it's possibly the choke is TOO much, it's running every so slightly rich, and causing the misfire. When you put it in drive, it causes a load, so it needs the rich mix. Put it back in Park, no load, doesn't require as rich a mix, begins to randomly misfire again.
Old Jan 12, 2014 | 11:04 AM
Killgore's Avatar
Killgore
There's new point, new condensor, new cap, new rotor. Could it just be something I don't need to worry too much about and just drive er anyways?
trucktech
Modular V10 (6.8l)
Mar 2, 2011 07:25 PM
Shooter00
Jul 6, 2010 12:45 AM
geraldo14
Apr 29, 2008 05:37 AM
WXboy
1983 - 2012 Ranger & B-Series
Mar 20, 2003 01:54 PM
