DEF pump making noise and leaking.
Old Jan 9, 2014 | 01:57 PM
skarms's Avatar
skarms
Hey guys,
I have a 2012 f-350 with no mods to the motor or exhaust. Today my check engine light came on. After I drove it a bit and parked it sounded like the pumps gears (for the DEF) were grinding along with what I'm assuming urea leaking from the top of the tank. I was wondering if anyone else had this problem in the past. The truck has 89000 kms on it and we had -38 degree weather this last weekend. Is it possible that the pump froze and broke open? Any help or advice would be greatly appreciated.
Old Jan 9, 2014 | 02:09 PM
Romeo Scorpion's Avatar
Romeo Scorpion
Originally Posted by skarms
Hey guys,
Have you filled your DEF tank recently? If so did you fill it right to the top? Overfilling can cause things to break when it gets below 12 degrees.
Old Jan 9, 2014 | 02:13 PM
skarms's Avatar
skarms
I bet that is what happened. I have prepaid maintenance and just had the truck serviced last week. When I got it back I could see white streaks from where the technician tried to wipe the urea that overflowed. I didn't say anything at the time because I didn't think it would cause me any grief. Thanks, i will be making some calls.
Old Jan 9, 2014 | 02:24 PM
tolliewolly's Avatar
tolliewolly
let us know what they do for it.
Old Jan 9, 2014 | 05:19 PM
skarms's Avatar
skarms
I had called the one Ford dealership and they told me that it may not be covered under warranty due to being over my km's. What I am going to find out is how something that wasn't even caused by driving isn't going to be covered when it was a Ford service center that over filled the reservoir.
Old Jan 9, 2014 | 06:33 PM
senix's Avatar
senix
The owners manual states to not overfill. Using the ford approved spout you would not be able to overfill.
So if the tech did not follow procedure then I would take it up with the servicing facility.
Old Jan 15, 2014 | 03:43 PM
FordServiceCA's Avatar
FordServiceCA
Official Ford Rep
Hey guys,
Hi skarms,
Please send me your VIN, full name, daytime phone number, and servicing dealer via PM and I'll check a few options out for you.
Bianca
KWEEKS
6.7L Power Stroke Diesel
Aug 8, 2012 04:37 PM
idiggplants
Jun 26, 2009 12:06 PM
scatgo
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Mar 6, 2008 09:03 PM
scatgo
Feb 26, 2008 10:11 AM
fordtruck88
Aug 18, 2004 11:57 PM
