1978 - 1996 Big Bronco
No brake lights
Old Jan 9, 2014 | 09:46 AM
bra$$monkey's Avatar
bra$$monkey
No brake lights
This Bronco is a BEATER with emphasis on bEATer.
I will only spend a little effort on this b4 just running trailer lights to the back & wiring it all new.
I have tail lights & occasionally turn signals.
I have no blown fuses.
The bulbs are good.
Just replaced the brake light switch.
Cruise control will not cancel when I hit the brakes but will if I use the turn signal.
Lastly.....someone spliced into the wire @ the switch & ran the wire to come component on the firewall behind the pedals. It has some sort of button on it.
Because the wires are potentially hacked I will toss on a set of trailer lights to get brake lights if I can't find it quick.
Old Jan 10, 2014 | 03:29 PM
bra$$monkey
I'm going to post this in rednekkedness thread.
I had a set of trailer lights - I bolted them to the sides of the bronco & wired in a thumb switch.
so now when I hit the brakes I can also hit the thumb switch & I have brake lights.
I found a pressure switch that you plumb into the brake line. $20 plus the fittings.
I will do that as soon as the weather is nice enough for me to want to crawl under the truck. Its all sloppy & icy now. maybe next month.
cdouglas75
Jul 23, 2015 08:55 AM
knash0727
Apr 21, 2013 01:24 AM
Lukes66
Feb 9, 2011 05:38 AM
wordenhutch
Kansas Chapter
Jun 3, 2006 03:21 PM
RangerPilot
General Automotive Discussion
May 27, 2006 05:30 PM
