6.2L V8 Discuss the 6.2L V8
1st mod
Old Jan 8, 2014 | 02:35 PM
brickman's Avatar
brickman
1st mod
The one thing I miss the most about my old F150 was the power pedals, the gas pedal on the new f250 just doesn't feel right it seems too far away in conjunction with the brake pedal. I solved that problem today, I removed the 3 bolts holding the gas pedal replaced them with 50mm long m8 bolts and spaced the pedal out using 3/8 nuts as spacers behind the gas pedal. I experimented and found that 2 spacers seemed to work best for me. This made a huge difference in comfort and also response from the gas pedal. this is probably the cheapest and easiest mod that I have ever done it cost a whole $2.00 dollars, took all of 10 minutes to do and has made the world of difference.
Old Jan 8, 2014 | 03:45 PM
Go Big or Go Home!'s Avatar
Go Big or Go Home!
Didn't your SD come with the power adjusted pedal button behind your steering wheel on left.?
Old Jan 8, 2014 | 03:50 PM
brickman's Avatar
brickman
No it didn't have that option, its an xlt. I got it of the lot as they had good discounts on the leftover 13's and there was only a few left in ontario at that price
Old Jan 8, 2014 | 03:55 PM
Go Big or Go Home!
Oh I see, still cool you got a nice SD at a good price!! How do you like your so far,, you got the 6.2 right?
Old Jan 8, 2014 | 04:14 PM
brickman's Avatar
brickman
Terrific truck yes it has the 6.2 and plenty of power had an 03 f150 5.4 super crew before.
systems
2015 - 2020 F150
Apr 12, 2019 09:35 AM
BIGTRUCKBIGRV
Sep 10, 2017 08:36 AM
projectSHO89
May 13, 2015 09:51 AM
Calamity Cowboy
Apr 3, 2013 08:28 AM
bronco252
Feb 17, 2011 05:48 PM
