Automatic Elevated Idle???
Old Feb 4, 2014 | 07:31 PM
GCLL's Avatar
GCLL
Originally Posted by OvalTrucker
Well, I think this is a safety issue.
I've posted this in another thread but I feel it needs to be known;
A friend of mine with an F350 6.7 has this same high idle situation. However, it almost caused a crash for him. He was approaching a stop sign at an icy intersection and applied the brakes. The front wheels slid on the ice as the rear wheels continued to push him into the intersection because the truck was "idling" at 1200 RPM. He put the truck in Neutral so the truck would stop. Sounds pretty dangerous to me.
I know I've seen the rear wheels of my truck spin while I was stopped in an icy area with the brakes on. Not hard braking, just enough to keep the vehicle from moving.
I'm seeing this as a pretty serious safety issue. If the dealer that has my truck right now can't come up with a satisfactory solution - I'll be escalating the issue.
Yes, I've had the same thing multiple times. I had to put my truck in park and turn it off the other day at the bank drive thru because my back tires were just sitting there spinning.
Old Feb 5, 2014 | 02:41 PM
OvalTrucker's Avatar
OvalTrucker
How many of you would double the idle speed of ANY vehicle.... and drop it in gear?
That is what is happening.
Normal idle speed is 600 RPM. High idle is 1200 RPM.
It doesn't sound like an "OK" thing to do to the drivetrain.
Old Feb 5, 2014 | 04:31 PM
doczenith1's Avatar
doczenith1
I've also noticed the high idle while in drive. Makes thing interesting on slippery surfaces.
On another note, with the somewhat warmer temperatures I've noticed that the high idle is also dependent on the ambient temperature as well as the engine temp. With single digit ambient temps and truck oil <140 the truck would idle around 1000+/- rpm but with ambient temps in the 20's its back down at 600 rpm with <140 oil temp.
Old Feb 5, 2014 | 06:06 PM
Romeo Scorpion's Avatar
Romeo Scorpion
I'd find hard to believe that this condition is not accommodated by the transmission control module programming. I know that in my truck it's pretty easy to tell that that is exactly what occurs when the idle is high. The transmission goes into both reverse and drive very smoothly. No clunk, bang or lurch. Years ago this could have been an issue, but not today. This trans ain't no C4 or C6.
Now imagine all the whining and complaining we'd be doing if the truck spit, sputtered and shook when we put into drive after an extremely cold start. Someone would be asking why they didn't provide a higher idle speed to eliminate it.
Old Feb 5, 2014 | 07:15 PM
kper05's Avatar
kper05
Ford has it programmed it to transition smoothly from high idle into gear, which it does.
I have had plenty of transmission issues and this isn't one of them.
If your RPM's drop after putting it in gear, that's normal.
If it's still 1200 RPM 10 seconds after you're in [D] then yes, that would be a big safety problem but that's not what it does.
Old Feb 5, 2014 | 07:21 PM
rtazz17's Avatar
rtazz17
Mine drops as soon as I put it in gear as well.I dont see that as an issue though.There is no loud clunk or thump.Seems pretty seemless.
Old Feb 6, 2014 | 01:00 PM
doczenith1's Avatar
doczenith1
Mine shifts smoothly in to gear and yes, the rpm's drop some but not down to normal when warm. If you let off the brake it definitely will move you down the road at idle faster than the normal 600 rpm idle.
Old Feb 6, 2014 | 06:30 PM
GCLL's Avatar
GCLL
Just a side note. Something I noticed today. If you leave the parking brake down and shift into gear from high idle. It does not shift so smoothly. I always use my parking brake because I often times have a trailer and it takes out some of the "clunk" when a trailer is pushing or pulling on the truck.
Old Feb 6, 2014 | 08:57 PM
TRENT310's Avatar
TRENT310
I use my parking brake all the time (probably why it is very loose feeling now) but I release it before putting it in any moving gear...
Often when idling in traffic I will pop it into neutral and back instead of using service brakes all the time.
The other issue is that if the truck is cold enough to be doing a temperature driven high idle, it's likely that everything else is cold. The transmission is definitely not as smooth when the fluid is below freezing.
Old Feb 6, 2014 | 10:14 PM
mrjc's Avatar
mrjc
My truck idles at 1000 RPM in "D" and it is a little unnerving on the slick road. It is -14 outside. I wished it would return to 600 when placed into gear.
BMW2
Sep 20, 2017 06:22 PM
KIDkiser
Mar 20, 2015 12:31 PM
PSDlongbox
Dec 8, 2013 09:19 PM
Andy's250
18
Dec 8, 2009 07:04 AM
david00f150
Jan 9, 2009 11:02 PM
