Just got my torque app running. At idle I am seeing ect of 186.8 and eot of 176.8. After driving around town for about 30 minutes. Are these acceptable?
Get vehicle to operating temp. Get to a place where you can drive for 15 minutes at 65mph on relatively flat ground. Check your deltas(your engine oil temp will be the same as the coolant temp or a little higher). All is done with the vehicle unloaded. Temp deltas up to 15* are acceptable.
Note: ambient temp is 22F
I'm thinking you have them posted backassward......the oil temp is, at least as far as I have ever seen, never colder than the water temp after running that long of a time so if that is the case your temps look great for the ambient temp being what you posted.
ok, just got back...at 70mph I had 190.4 ECT and 194.4 EOT at cruise and 197.5 was the highest it went when I did a couple WOT pulls from 50-80 back to back.
I wanted a baseline for right now when it is 15 degrees out vs in the spring/summer. I have been wanting to do a flush and switch to ELC and replace the thermostat when I install my coolant filter. I just don't think I will have time until spring.
mine has dropped a little. around town , summer or now it stays the same but now on the highway its dropped maybe 1-2 degrees. i usually stay at 190-197/198
