Flywheel/clutch problems
Old Jan 7, 2014 | 11:53 AM
Eddillard79's Avatar
Eddillard79
I have a 1985 F350 Dually rollback with a t19 trans. I just bought the truck so don't know to much. The problem I'm having is I've noticed oil leaking on/around my flywheel. It's looks like motor oil, but I don't notice my engine losing oil (but I've only had the truck for a week). I do need clutch work, and a throwout bearing (i hear banging/squeaking) Where might this be oil leak coming from? Any ideas would be great
Old Jan 7, 2014 | 12:33 PM
airsoft1779's Avatar
airsoft1779
Might be from the rear oil seal on the engine. I had to replace that on mine because it was leaking from the same spot.
Old Jan 7, 2014 | 02:42 PM
Eddillard79
Thanks for the info. If I have someone replace my clutch & throwout bearing, is it much work to replace the seal?
Old Jan 7, 2014 | 04:57 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Is your truck gas, or diesel?
It's not uncommon for 460 engines to leak at the oil pressure sender (directly above the bellhousing)
Poke around back there with a mirror and have a look.
Old Jan 7, 2014 | 05:06 PM
Eddillard79
It's a 7.5l gas. If it is leaking around the oil pressure sender, do I just replace that part?
Old Jan 7, 2014 | 05:09 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You can try to tighten it, but I just replaced it.
It is in a tight spot between the EGR valve and the firewall.
Look for a little tin can with a wire on top.
Old Jan 7, 2014 | 06:28 PM
Eddillard79
@ardwrk, thanks for the help!
Old Jan 7, 2014 | 06:31 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Welcome to the forum!
Hope it turns out to be something a whole lot easier than a RMS.
thatranger
May 17, 2013 11:32 AM
wwgk1980
Jan 7, 2012 11:34 AM
ola1234
May 22, 2011 08:11 AM
willy3486
Oct 11, 2010 09:30 AM
ff1210
Feb 27, 2010 02:07 AM
