Think I popped a freeze plug
I moved back to school yesterday. Drive the ol idi from Galveston county tx to Tulsa Oklahoma. 500 miles pulling a trailer, truck did flawlessly. I was actually quite proud of the truck lol
This morning it was 3 degrees, I went out this afternoon and found coolant all over the ground under my truck. It's coming from the passenger side toward the front of the block. I can see it dripping down the exhaust manifold, down by the head gasket, and then down the block to the ground. Now, my ******* being from south Texas, realized my antifreeze is mixed up 50/50. All my buddies say they run straight antifreeze during
The winter. My antifreeze was getting kinda thick on the ground. So I think it froze and I popped the front freeze plug on the front of the head. I can't actually see it because the fuel filter housing is bolted right over it. Does this make sense to y'all?? Freeze plug? I jus want to make damn sure before I take the truck apart in the parking
Lot. Thanks
Lot. Thanks
Received 3,287 Likes
on
on
the coolant is the corrosion inhibitors,sca's,antifreeze and other good stuff.the water is the cooling part.as noted,the 50/50 mix is what you want.running straight antifreeze,not only would the good stuff in the coolant not do it's job to protect the engine,but it would overheat too.i would guess you had more water in there than you thought you had if she froze up and blew a freeze plug.
one these should be used every 3 months or so;
Thanks for the input fellas. It isn't that heater hose...it's further forward than that. I can see it leaking down the block by the fuel pump. And on the front I the ex mani. So I'm pretty damn sure it's that freeze plug on the front of the head. Does anyone know what size that freeze if is?? I want to have one before I take it apart
Denim dan996
07-13-2015 10:54 AM
JimBenson41
05-06-2006 01:23 AM
