6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Fuel gel
Old 01-06-2014, 09:30 PM
rblaine9000's Avatar
rblaine9000
rblaine9000 is offline
Fuel gel
well my truck gelled on me first time ever had this happen to me... not fun.
hopefully it warms up some tomorrow.
Old 01-06-2014, 09:31 PM
rblaine9000
btw has anyone changed their fuel filters before? especially the one on the rail? wondering if I need to remove drive shaft to access???? thanks!
Old 01-06-2014, 10:10 PM
reaganla's Avatar
reaganla
reaganla is offline
Its tight but is accessible without removing anything. A 36mm socket (same as top) to remove cap
Old 01-06-2014, 10:20 PM
RM2738's Avatar
RM2738
RM2738 is offline
I recommend running power service diesel supplement. Gray bottled during warmer months and white during freezing months.
Old 01-07-2014, 06:25 AM
rblaine9000
Actually had poured power service in on top of full tank of fuel and drove to work. Warmed truck up before I left work and then she laid down on me. It was -11 yesterday. Thanks for the reply
Old 01-07-2014, 01:16 PM
Ghost00TJ's Avatar
Ghost00TJ
Ghost00TJ is offline
After mine gelled today- I put a 32 oz bottle (911) in the 6.4L, started it up and it ran but with check engine light. put in some fresh fuel and within a mile the engine light turned off an it seems to be running all happy again. Thank 911 and a 32* rise in temps to 22*F.
Old 01-07-2014, 03:43 PM
golfmedik's Avatar
golfmedik
golfmedik is offline
Be careful using 911! If there is any water in the system it will send it straight through the fuel system and through the separator and damage the fuel system. 911 was intended for trucks older than the ones we have. It was not made for our trucks. It contains alcohol and is an emulsifier. Contact Senix and he can give you the info on it.
Old 01-07-2014, 06:37 PM
ljutic ss's Avatar
ljutic ss
ljutic ss is offline
+1 911 is fine for low pressure injector pump diesels.
Slowandsteady
2017+ Super Duty
02-24-2018 08:03 PM
JamesB128
1999 to 2016 Super Duty
12-18-2016 10:46 AM
white Buffalo
18
11-13-2014 06:44 PM
M. Kelly
11-08-2011 08:11 PM
444stroker
25
06-10-2003 03:39 PM
Quick Reply: Fuel gel
