Cold Weather Hutch Mod Issues
Old Jan 8, 2014 | 07:57 AM
  #31
Dan V's Avatar
Dan V
Here's a start:
Fuel Cooler results
I pulled this:
I spoke to a Caterpillar engineer about fuel temps.
I just asked, "what temp does diesel fuel need to me in a HUEI injected engine?"
His response was concise and too the point. Cat engineer: "120 F is OK but hotter than we like, 140 F is dangerously hot. Fuel over 140 F loses density which slightly hurts hp but the lubricity of the diesel falls off dramatically increasing wear on fuel system components significantly."
We end up w/ hotter fuel w/ the regulated return system than a stock set up.
I remember my thinking on putting the cooler before the fuel entered the heads. I wanted hotter fuel in the tank since I gelled up once w/ my mixer valve pulled out.
out of this thread Fuel Cooler test results
Now where is this is today? Don't know, but it was a question back in the day.
Old Jan 8, 2014 | 08:51 AM
  #32
jetdoc's Avatar
jetdoc
Originally Posted by Dan V
Here's a start:
Fuel Cooler results
That made for some interesting reading....Thanks!
Old Jan 8, 2014 | 08:59 AM
  #33
clux's Avatar
clux
The Hutch mod definitely impacted my cold weather operation. And a full regulated return hasn't completely solved it, either. The mixing chamber does serve an important function in cold climates, I have considered removing the screens and putting it back in myself.
Old Jan 8, 2014 | 09:34 AM
  #34
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Hutch lives in Augusta Georgia. Texas Towncar lived in Texas. Bob Riley lives in Florida. Strictly Diesel/ITP Diesel (now one company) hail from Arizona...
In other words, I've noticed that the proponents of these factory equipment deletions and substitutions that remove or modify OEM engineering like the fuel sending unit apparatus in the tanks, the intake air heaters, the EBPV's, etc... are not test driving their modifications in Saskatchewan.
The marvel of the 7.3L is that it continues to run for hundreds of thousands of miles DESPITE the things we do to it.
Old Jan 8, 2014 | 10:06 AM
  #35
jetdoc's Avatar
jetdoc
This post should be made a sticky.
Old Jan 8, 2014 | 07:28 PM
  #36
white Buffalo's Avatar
white Buffalo
Here's a start:
Fuel Cooler results
I pulled this:
Good post & memory Dan...........
Ah, the old Diesel Stop days - the old forum wars & internal arguments. You could always log on at any time of the day and read a good fight............Wow, it's been about 10 years!
Anyhow, I wonder what ever happen with Dennis' spring fuel temp test and what he determined. Also, this thread was about 2 years prior to the introduction of ULSD. Which has less lubricity than it's predecessor (prior to adding additives at the terminal). I wonder if the fuel change had made things worse or better?
I don't even think I know anyone in a street application that is running a fuel cooler.......do you?
Old Jan 8, 2014 | 07:32 PM
  #37
clux's Avatar
clux
I know somebody....................
Old Jan 8, 2014 | 07:35 PM
  #38
white Buffalo
Well, I figured if anyone did........I would probably be you
edit: PS, you just hit 9,000 posts ---- 1,000 to go
Old Jan 8, 2014 | 08:08 PM
  #39
Dan V's Avatar
Dan V
If you go to Riley's Dieselsite and select either the SD or OBS CPR fuel system, they have a cooler included.
I run regulated return, but still have the factory tank pick-up...no hutch mod. I can't tell you what the fuel temp is after running 250 miles between fuel stops (29g tank), but when pulling the horse trailer (20k combined) when I stop for fuel in the summer....I'll get a vapor, like a fog coming out of the filler neck.
It makes me wonder.
Old Jan 8, 2014 | 09:47 PM
  #40
JOHN2001's Avatar
JOHN2001
My inline filter gelled up on me this morning on my way to work. I dumped diesel 911 in the tank swapped the filters and went about my way. I have the Napa filter for the hutch mod.
white Buffalo
37
Jan 26, 2014 11:06 PM
dcara
Jul 20, 2009 05:19 PM
Hotwheelbill
36
Mar 21, 2008 02:25 AM
rad1026
Nov 6, 2006 05:25 PM
MRBASS
Feb 28, 2006 01:54 PM
