Need some help choosing a speedometer.
Old Jan 7, 2014 | 07:35 AM
topmoo's Avatar
topmoo
I got a speedometer from SpeedHut that runs off GPS. A small antenna with a magnet sits on top of the dash. Not only does it tell you your speed, run the odometer, it also tells you your elevation. No cables to run, works with anything as long as you are outside - doesn't work in a parking garage or in a tunnel.
Old Jan 7, 2014 | 08:08 AM
tinman52's Avatar
tinman52
Welder User
Originally Posted by Holehawgg
Are the electronic speedos controlled by an inboard computer or are they independant of the vehicle computer?
And If I'm lucky enough to be driving the 49 I will definatley be over.
No computer required. The last one I did, (Autometer) was simple....bolt the sensor into the trans, plug in the wires and hook up your power source.
Can't wait to see your truck on the road....stop by anytime.
Old Jan 7, 2014 | 08:29 AM
Holehawgg's Avatar
Holehawgg
Perfect. Thanks everyone. I have looked into the gps ones and I like them alot. Also found a cool electronic one and if its as easy as Tinman says it is to hook it up I may go that route. Both are bookmarked hopefully for some not so future usage.
Remi. Oh ya thanks for the multiqote lesson. Always seen that button but never tried to figure out what it was. The less buttons I push the longer my computer runs without a visit to the puter doctor.
Old Jan 7, 2014 | 10:56 AM
Moe Craig's Avatar
Moe Craig
What about those days that it's not nice out, another words cloudy outside? I sometimes have problems with my GPS when it's cloudy out... sounds like it's the same...
Old Jan 7, 2014 | 11:03 AM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Remi, aren't you running EFI? I was thinking you were, if so you still need the speed sensor in the tranny to feed signal to the computer. A GPS speedometer would be cool.
Old Jan 7, 2014 | 11:08 AM
raytasch's Avatar
raytasch
Believe Nothing
So we don't get locked onto a dedicated GPS speedometer, consider a GPS navigation system. Mine plugs into the power port or cigarette lighter and mounts to the windshield or anywhere convenient. It is very nice to have a map program as well as a speedometer in one device. Guess I should have made my point a bit better in my first response to this thread.
Old Jan 7, 2014 | 01:26 PM
Holehawgg's Avatar
Holehawgg
Good Idea. I did buy a small gps nav system for the truck. I can use it as well as an electronic one in the guage cluster. There problem solved. This is a good site.......
I dropped the efi and went the simple route with an Edlebrock 1406 carb I was using on the jeep before I changed it over to efi. Truth is I know how to work on the carb system... efi...did I mention I don't really like electronic things. They scare me....
Old Jan 7, 2014 | 01:53 PM
Jeff and Nicolle
LOL you probably mentioned it somewhere, I just haven't caught up!
I have thought about the same thing, but keep insisting to stick with it..
Old Jan 7, 2014 | 02:39 PM
tinman52's Avatar
tinman52
Welder User
Good question Jeff, maybe I mis spoke.......I never thought about EFI. Might complicate how the speedo gets tied into the system.
I'm used to doing things "caveman" style and am not up on all this newfangled stuff.....
The electric speedo should still work as a "stand alone", but what the computer requires is another issue.
Old Jan 8, 2014 | 12:18 AM
ben73058's Avatar
ben73058
Hey Holehawgg,
I'll chime in on this one. We went the electronic speedo route with some concern as I'm normally not a big electronic guy. It was pretty easy - we had to find a flat mile stretch of marked roads to calibrate the thing. That was about it - no running wires, selecting speedo gears, how big are my tires, etc.
One thing I didn't like was we chose to do the calibration a second time
just to make sure we got it right. It erased the mileage we had already done on the odometer. It could easily have been user error but I really want to show the true miles on the odometer.
Looking good up there - think warm thoughts. It got to 14 farenheit last night here in Austin - if it got that cold here I don't even want to think about where you guys live.
Ben in Austin
1950 F1
Old Jan 8, 2014 | 05:33 PM
topmoo's Avatar
topmoo
I had one in my '65 that worked great even when it was raining, and two friends who have them in their resto's. I think the antennas are much better than the ones in the navigation GPS's.
Old Jan 8, 2014 | 06:49 PM
carnut122's Avatar
carnut122
I have mine up and running and keep wondering if I made the right choice (shrug).
Brad9907
Electrical Systems/Wiring
May 29, 2019 04:36 PM
Jeremiah Clark
Apr 10, 2012 07:49 AM
mhancock2
May 5, 2011 10:13 PM
rashanny
24
Mar 31, 2011 11:14 PM
fordranger68
13
Feb 29, 2004 10:56 PM
