Speedometer is kicking my butt
Old Mar 21, 2011 | 05:57 PM
mhancock2's Avatar
mhancock2
Ok this thing is kicking my butt. I have changed the vehicle speed sensor twice. I can turn the cable and it works fine. I install the vss in the truck and the speedometer doesn't work. I don't understand.
Old Mar 21, 2011 | 06:03 PM
IDIDieselJohn's Avatar
IDIDieselJohn
The plastic gear inside the transmission could be worn.
Would help to know abit more on the truck, year, mileage etc.
Old Mar 21, 2011 | 08:43 PM
catfish101's Avatar
catfish101
??? Turned the cable and replaced the VSS. What year is your truck?
Old Mar 22, 2011 | 12:15 AM
84-6.9L's Avatar
84-6.9L
He might be talking about the vss for the rabs? Anywho if you have a cable check the gear for wear.
Old Mar 22, 2011 | 11:01 AM
BlueOvalBud's Avatar
BlueOvalBud
Need to know the year of the truck.
Manual or auto trans, 4x4? Those would be helpful too.
Up to 91 is cable driven, and the 92+ is electric as far as I know...
Old May 5, 2011 | 05:56 PM
mhancock2's Avatar
mhancock2
It is a 1991 2wd truck. It has a manual transmission. ok the gear is missing, that is probably the issue. I will see if I can get one.
Old May 5, 2011 | 10:13 PM
84-6.9L's Avatar
84-6.9L
What is you rear gear ratio? Tire size? How many teeth are on the one in the trans. The driven gears come in tooth counts from 16 to 21 teeth
cagomez
Sep 23, 2011 08:12 PM
cagomez
Sep 20, 2011 04:46 PM
madmann
2004 - 2008 F150
Dec 20, 2010 10:06 PM
spitball
Mar 31, 2004 10:03 AM
RobertNooy
Mar 30, 2003 05:13 PM
