Speedometer not working.
Old Apr 9, 2012 | 04:58 PM
Jeremiah Clark's Avatar
Jeremiah Clark
I have a 1990 F-150 4x4 5-speed. Recently purchased and speedometer was not working. Removed cable and was able to get a reading by spinning it by hand. The gear in the hole for the cable felt pretty smooth. I installed a shim (thanks to an Arnold Palmer tea can) and tightened down the bracket holding it down. Still didn't work, but I believe it caught every now and then. When ever I drove over a big enough bump the the speedometer would pick up enough to catch my current speed. So I believe it is the gear in the actual transmission that needs to be replaced. Just wondering if any one else agrees with that diagnosis.
Old Apr 10, 2012 | 06:57 AM
Lazy K's Avatar
Lazy K
Probably right. however might be worth checking that the squared end on the inner cable at the speedo head is good.
Old Apr 10, 2012 | 07:49 AM
GNR22's Avatar
GNR22
zip tie the cable up to something. That usually fixes the issue. Pretty common issue for about every ford using this speedometer set up in this era.
Brad9907
Electrical Systems/Wiring
May 29, 2019 04:36 PM
mzavenm
Jun 19, 2018 07:19 PM
rashanny
24
Mar 31, 2011 11:14 PM
72sportcustom3906.4l
Jun 20, 2009 05:56 AM
fordranger68
13
Feb 29, 2004 10:56 PM
