Sponsored by: Real Truck
spare tire space
Old Jan 6, 2014 | 06:04 PM
Winegrower2013's Avatar
Winegrower2013
spare tire space
The 03 F250 7.3 I bought came with 18" rims but is not lifted. I noticed today that the spare tire is a 16" rim.
How much of a problem is this?
Would a larger tire on a 18" rim even fit in the space provided for the spare tire?
Please advise.
Old Jan 6, 2014 | 06:12 PM
redford's Avatar
redford
FTE Leadership Emeritus
It isn't the rim size as much as it is the tire diameter. Just because someone has 18 inch rims does not always mean that they have larger diameter tires.
Old Jan 6, 2014 | 06:18 PM
Winegrower2013
I guess I asked the question wrong. I understand the tire size is not dependent on the rim size. I meant to ask:
1- does putting on a spare with a smaller diameter than the four wheels cause damage?
2- what do people do when they want to carry a larger overall tire diameter to go in the space for the spare.
I could measure the space but there is a exhaust pipe there so I just thought I'd ask those with more experience for ideas.
Thanks for responding.
Old Jan 7, 2014 | 01:38 PM
89LX306's Avatar
89LX306
1. It can damage the clutches in the rear LSD. I personally would swap the spare to the front end if I had a flat on the rear.
2. I was able to fit a 315/75/16 on a factory spare rim under the truck with stock exhaust. It was tight! With 4" exhaust it no longer fit on my truck.
Hope that helps.
Old Jan 7, 2014 | 01:45 PM
MisterCMK's Avatar
MisterCMK
I wouldn't worry about any wear on the LSD clutches provided you are not driving it on a long trip with a different sized tire on the rear.
My spare tire is a 31.8" tire. The tires on my truck are a 34.1" tire. My solution to the spare tire size was to do nothing because it is a waste of money to put a bigger spare tire under the truck.
Old Jan 7, 2014 | 02:34 PM
jstnromero's Avatar
jstnromero
You will be fine with a smaller diameter spare for emergency use. (Think small donut spare tire on a car). I would not drive far with it though, just so you can get somewhere to get the truck fixed.
Old Jan 7, 2014 | 04:03 PM
Winegrower2013
Thanks everyone for the responses.
Wes Hightower
Sep 30, 2017 09:50 AM
ycis
Sep 10, 2013 09:03 AM
ATSW FX4
2009 - 2014 F150
Jun 25, 2009 05:36 PM
92_FlareSide
Sep 5, 2006 10:02 PM
happycamper116
Mar 30, 2006 11:29 PM
