Sponsored by: Real Truck
Downgraded front clip?
Old Jan 4, 2014 | 12:27 PM
Grizzly4x4's Avatar
Grizzly4x4
Hey everybody, Happy new year.
I've been reading through some of the older posts and have seen a bunch of threads on upgrading to newer front clips, mirrors, interior, etc...
Personally, I've always liked the front ends from the 99-04 models, which is why I just bought my 04 besides for the price and condition. I'd seen a deal on an 08 at the dealer that I was tempted to buy until I found my truck. So my question is for the next truck, is it possible to take a newer truck and "downgrade" the front end to the older style?
I know you have to do a lot of cutting and fabricating to go to the newer styles so would it be easier to go back?
Old Jan 4, 2014 | 12:39 PM
rollerstud98's Avatar
rollerstud98
You can do anything you want to do as long as you are willing to pay for it. I think going for your 04 look on anything newer than an 07 is going to be more hassle than it is worth though. Even on the 05-07 probably not as easy as upgrading the earlier models to the 05-07 look.
Old Jan 4, 2014 | 07:07 PM
crown14's Avatar
crown14
You would need to swap back to an early header panel to put the older headlights on a 05-07.
Old Jan 4, 2014 | 08:24 PM
02TB250's Avatar
02TB250
I'm going to say not really feasible. To put an 08 front end on an older truck you have to weld in spacers to fit the fenders properly as well as modify the Frame. So to fit the older stuff you would have to switch out the fenders and cut the inner fenders and modify the Frame.
Sent from my Galaxy using IB AutoGroup
Old Jan 5, 2014 | 09:10 AM
SuperDutyScaler's Avatar
SuperDutyScaler
I prefer my 04 body over all the other years but IF I buy a new truck I won't be going back to the older body look, trust me the new body will grow on you after you buy it
Sent from my iPhone using IB AutoGroup
Old Jan 5, 2014 | 09:46 AM
Jeff Watts's Avatar
Jeff Watts
This is the first time I've heard that it requires cutting, welding, and fabrication.
Looks-wise, I prefer the 2008-2010, but I'm not giving up my front leaf springs.
Old Jan 5, 2014 | 11:14 AM
SDSC4X4's Avatar
SDSC4X4
Taking an 05-08 back to the 99-04 look wouldn't require cutting/welding if you change the header panel. Newer (than 08) models would involve extensive work.
Hi-Teck may be able to help you out. https://www.ford-trucks.com/forums/1...0-shipped.html
BTW Jeff, I'm with you on the front leafs!
Old Jan 5, 2014 | 11:22 AM
02TB250's Avatar
02TB250
Only for the 08+ does the truck require modifications. the 05-07 can be done by swapping parts
Old Jan 5, 2014 | 11:23 AM
02TB250's Avatar
02TB250
New front end was started in the 2008 model year.
Old Jan 5, 2014 | 11:28 AM
SDSC4X4's Avatar
SDSC4X4
My bad! Didn't mean to cause confusion. Should have said: 08 and newer....
Old Jan 5, 2014 | 01:12 PM
SuperDutyScaler
I feel ya I'm not ever getting rid of my leaf spring Super Duty
Old Jan 5, 2014 | 01:21 PM
Snowseeker's Avatar
Snowseeker
I have a spare 03 header panel laying around.
Old Jan 5, 2014 | 02:09 PM
crown14's Avatar
crown14
And I have headlights/cornerlights...
Old Jan 5, 2014 | 02:41 PM
redford's Avatar
redford
FTE Leadership Emeritus
The '08 and newer trucks have a revised front frame. This was done because of the larger heat exchangers mounted in the nose, like the radiator, trans cooler, intercooler and such. An '07 and earlier nose probably won't have enough room for the upgraded cooling bits.
Old Jan 5, 2014 | 02:45 PM
Snowseeker's Avatar
Snowseeker
I think there would be enough room for the fenders, hood, grill, and lights but I think a custom bumper would have to made to fill the gaps of the different frame and taller front end.
I think the OP should try it out and post pics.
