Electric Fan Conversion
Old Jan 6, 2014 | 06:47 PM
dmccorkle911's Avatar
dmccorkle911
I ran mine today for 1/2 and hour. All was good. By the way, just bought a fan off craigslist for $40.00.
Old Jan 6, 2014 | 06:53 PM
dmccorkle911
I tow a 30 ft. 5th wheel with my truck so my engine is always hot as hell! What wiring setup would you recommend? Not sure I would ever just need low speed unless it is -1 like today I guess.
Old Jan 6, 2014 | 07:07 PM
co425's Avatar
co425
Delta current control. Expensive but worth it.
Old Jan 6, 2014 | 07:33 PM
psychlopath's Avatar
psychlopath
Originally Posted by Dave145
My starter literally is frozen! Have to smack it...
I had to do that today and it's not even negative anything here. I've been in some very miserable weather and NEVER had to do that before. Wonder what gives.
If you only want one speed, I'd suggest a thermal switch of your choosing, a relay and some circuit protection. I used a Napa ECHFS151 switch to run low and high speed, but it required some machining to get it to fit into the thermostat housing.
Partsplus part numbers: 500-001, 330-079 (x2), 330-080 (x3), and 075-140 will get you all the relays and cool little relay bases you need, INCLUDING one shiny new 70 amp unit AND a sweet relay wiring diagram. Those should all be 5 prong relays.
BUT, I have since ditched those relays in favor of some factory fan relays from a Cadillac something or other that are weatherproof, come with built in snubber diodes and came with a cool little bracket to make a very stock looking install.
Old Jan 6, 2014 | 07:41 PM
HIO Silver's Avatar
HIO Silver
Looking at the big picture.......Edelbrock E-Street EFI! It's programmable and can control two-speed fans.
Old Jan 6, 2014 | 09:34 PM
Scoop531's Avatar
Scoop531
I'm always in the salvage yards so what years and what parts should I grab of a mark 8
niko20
Apr 26, 2019 09:53 PM
TheFoum913
Dec 29, 2013 01:11 AM
wicat3
15
Feb 14, 2012 10:04 PM
DIRTY_D
Apr 15, 2008 12:48 PM
tdg038
Apr 6, 2005 09:35 PM
