99 E-250 bolt pattern
Old Jan 6, 2014 | 02:20 PM
DaytonaTunnel's Avatar
DaytonaTunnel
I need to know if the bolt pattern on a 99 E-250 (drum brakes) is metric, or the old school 8x6.5 ? I know the F-series changed over to metric on 99, but did the E-series change over as well ? THANKS
Old Jan 6, 2014 | 02:30 PM
blageurt's Avatar
blageurt
No...E-Series is the Same as it ever was...same as it ever was.....same as it ever was......This is not my beautiful house...this is not my beautiful wife.....etc.etc.etc.
Old Jan 6, 2014 | 02:32 PM
DaytonaTunnel
So what does that mean, metric or standard ? I'll ***-u-me it is still standard ??? Thanks.
Old Jan 6, 2014 | 02:34 PM
DaytonaTunnel
I will ask a second question, is the rear a DANA or a Sterling ?
Old Jan 6, 2014 | 02:35 PM
blageurt's Avatar
blageurt
8 x 6.5........rear is DANA 60 ....unless you have a Cube Van.... .(then Dana 70 or 80 ) Sterlings were F Series Only.....(At least here in Canada ) You don't know the Talking Heads Song ? ( Once in a LIfetime )
Old Jan 6, 2014 | 02:37 PM
DaytonaTunnel
8 x 6.5........rear ir DANA 60 ..Sterlings were F Series Only.....
That is a HUGE help, thanks !!!!
Old Jan 6, 2014 | 02:41 PM
blageurt's Avatar
blageurt
What is your BB ford in the eliminator Daytona in your Sig ? is it 460 based ?
Old Jan 6, 2014 | 02:49 PM
DaytonaTunnel
1150 Dominators, 8-71 Hampton, Blue Thunder heads, SVO block, Diamond pistons, forged rotating assembly. I run the blower 18% over on 9:1 static, spin it around 6.5-6.7K, 1050hp.
[IMG][/IMG]
[IMG][/IMG]
Old Jan 6, 2014 | 03:05 PM
blageurt's Avatar
blageurt
HOLY BUCK.......WOW........I feel like getting Naked and running around ...........Pee on the ground.........
Is it Alcohol ?
Old Jan 6, 2014 | 03:10 PM
DaytonaTunnel
LOL, it's actually pump 92. Intercooler with unlimited 60* water going through it, and the fact it's a pumper (jet drive) it never see's what would typically be a "load". It's not possible to "lug" a jet pump, they just rev to where you want them.
I started with a normal 460 2 bolt block, this is what happened.....
[IMG][/IMG]
Old Jan 6, 2014 | 03:22 PM
blageurt's Avatar
blageurt
You should use the 70's blocks like mine ( Truck /Lincoln ) Internally balanced....
UNLESS you can find a Interceptor 428 block ( 69-71) .....they were real stong....
I know a guy who has one with the 429 BOSS heads and he makes 1500 all day with dual quads ( Holley 750 square Bore ) ..he uses Av gas and lead additve and has MSD ( Very modified as he is a Electronic geek ) Cayuga Motor Speedway stock car racing track Considering it is in a 77 Lincoln Town Car ( Gutted with Roll cage )
Old Jan 6, 2014 | 03:29 PM
DaytonaTunnel
That WAS a 70's block, just not a 4 bolt unit. A 428 PI is a nice find, but they split right down the center when you lean on them hard, besides being an FE block. I think I'll stick with my 385 series SVO block, it seems to be holding up well .
77 "Town Car"...NICE !!!
Old Jan 7, 2014 | 08:00 AM
JWA's Avatar
JWA
That is indeed one very, very purty motor. (Extreme attention to detail, obviously no upper budget?)
Not sure I'd be naked and peeing on the ground BUT I'd certainly be in awe seeing it in person!
Old Jan 7, 2014 | 01:40 PM
DaytonaTunnel
Thanks for the compliments, I am a bit of a detail nut
Old Jan 7, 2014 | 02:47 PM
JWA's Avatar
JWA
Sometimes too much is just the exact amount necessary!
FrostReeves
Oct 6, 2016 03:28 PM
HAWG06
Oct 21, 2011 10:19 AM
sledguy24
Sep 4, 2007 10:41 PM
Flea
Jul 9, 2007 07:19 AM
'96 F-250
Feb 25, 2006 07:42 AM
