1978 - 1996 Big Bronco
tailgate torsion bar
Old Jan 8, 2014 | 08:34 PM
greystreak92's Avatar
greystreak92
Ended up taking the added step when replacing the entire tailgate (cancer patient) of having the local Rhino Linings shop do the INSIDE of the gate before I reassembled the guts. The Fe2O3 can't even begin in the new one which is is the typical cause for the bracket or torsion bar to give way.
Remember that the end of the bar may be jammed against the outer skin when the gate is up but torsion is the opposite direction (towards the inside of the gate) by the time the gate has been lowered. Once the bar takes the weight of the gate the pressure being exerted is huge when you consider how heavy a fully loaded tailgate is what with window, glass, inspection cover, window motor and regulator all inside.
Old Jan 9, 2014 | 03:41 AM
GruesomeJeans's Avatar
GruesomeJeans
A powered gate would be really awrsome. If you could figure out how to get it to work effectively and efficiently, it would be a great option.
Old Jan 9, 2014 | 05:58 PM
peganit2's Avatar
peganit2
Both very good points!
D7O
May 21, 2022 02:20 PM
kh0432
Oct 8, 2016 01:11 PM
Lastwagen
6.7L Power Stroke Diesel
49
Nov 2, 2014 02:20 PM
StrauntonBronco
22
Nov 29, 2003 01:24 PM
coolcasper
Mar 2, 2003 05:09 PM
