V/B spring question
Old Jan 29, 2014 | 04:45 PM
crazytwo's Avatar
crazytwo
The stop is on the half leaf. What is it called?
Old Jan 29, 2014 | 04:50 PM
robert_l_ross's Avatar
robert_l_ross
OH, THAT one...ummm...isn't it called a rubberbabybuggybumper?
Old Jan 29, 2014 | 05:33 PM
LivingLarge's Avatar
LivingLarge
OEM REAR AXLE LEAF SPRING BUMPERS 2000-2005 FORD EXCURSION #1C3Z-4730-AA
Old Jan 29, 2014 | 05:57 PM
robert_l_ross
Give that man a cee-gar!!
Old Jan 29, 2014 | 07:52 PM
crazytwo's Avatar
crazytwo
Thank you. Mine looks like it was eaten by a mouse. Is there something other than stock like Timbren?
Old Jan 29, 2014 | 10:09 PM
HiZ's Avatar
HiZ
Anyone have a lead or source for springs to do the mod?
Kind of bored not working on this thing lately you know
Old Jan 29, 2014 | 10:18 PM
robert_l_ross
HiZ...you can buy new from dealers like Tousley, or you can check the recycle yards around your area. In my area, the "regular" recycle yards didn't have trucks bigger than 1/2 ton, so to find the springs for mine I had to look for 'heavy truck' recyclers. There I found three 250/350 trucks and between those three I found a V code and B code set, still on the truck.
Have you checked via Google or the like for auto dismantlers or heavy truck dismantlers in your area?
Old Jan 29, 2014 | 10:37 PM
HiZ's Avatar
HiZ
Decided to pull the trigger today and yes I started to call around w/o much luck
I did a google search but at the same time was not positive about getting the correct springs!?! I'm going to keep at the local yards to see what I can find.
Thank you though
Old Jan 29, 2014 | 10:39 PM
HiZ's Avatar
HiZ
Ford Leaf Springs, Ford Truck Leaf Spring Replacement
Anyone comment on these guys?
Old Jan 29, 2014 | 11:18 PM
crazytwo's Avatar
crazytwo
Sorry I hijacked the thread. Back to your regular programming.
Old Jan 29, 2014 | 11:19 PM
robert_l_ross
Originally Posted by HiZ
Hmmm...curious...if the spring rates are same as OEM, that might be a good resource!
Old Jan 30, 2014 | 12:55 AM
Stewart_H's Avatar
Stewart_H
Do a quick search. We've discussed SD Springs for a few years here in the Ex forum. Them and Husky Springs have been talked about previously.
Check out this thread starting with my post here: https://www.ford-trucks.com/forums/1...l#post12515006
Stewart
Old Jan 30, 2014 | 12:59 AM
  #28
superdave02f552's Avatar
superdave02f552
How can they be that cheap? I may get my springs sooner than later.
Old Jan 30, 2014 | 01:06 AM
  #29
Stewart_H's Avatar
Stewart_H
Cheaper steel? Not required to meet OEM specs for the kind of steel?
Who knows. But it's only $40 bucks cheaper than OEM Ford V codes.
Stewart
Old Jan 30, 2014 | 01:12 AM
  #30
EXv10's Avatar
EXv10
You like me so much you are stealing my jokes.
