check engine light came on, ran codes po171,172 po303,306
well figure it is the coil packs and now i'm losing power when driving drives like crap! how much will it cost me to replace or fix
If you're at 100K miles then it's also time to change the spark plugs. If the plugs are okay then the least expensive COPs are on eBay, locally they run $50-$70 each. You didn't tell us the specs for your vehicle so we cannot give you a link to the correct COPs to buy, you'll have to search for them yourself.
thank you i just call a ford mech. and he said its cheaper just do the coil packs if i can yourself he told me that it will definitely cause my issues just order coil packs online hopefully that is the issue
